1 - 20 of 25 Posts
Item
Measurement
Qualification
Specification
DIMENSIONS: 4-door
Overall length
4,489 mm (176.7 in.)
Overall width
1,752 mm (69.0 in.)
Overall height
1,435 mm (56.5 in.)
Wheelbase
2,700 mm (106.3 in.)
Track
Front
1,499 mm (59.0 in.)
Rear
1,528 mm (60.2 in.)
Ground clearance
154 mm (6.1 in.)
Seating capacity
Five (5)
DIMENSIONS: 2-door
Overall length
4,440 mm (174.8 in.)
Overall width
1,751 mm (68.9 in.)
Overall height
1,396 mm (54.9 in.)
Wheelbase
2,650 mm (104.3 in.)
Track
Front
1,499 mm (59.0 in.)
Rear
1,526 mm (60.1 in.)
Ground clearance
154 mm (6.1 in.)
Seating capacity
Five (5)
WEIGHT
Gross Vehicle Weight Rating: 4-door (GVWR)
DX, DX-G, and LX
1,665 kg (3,671 lbs)
EX
1,695 kg (3,737 lbs)
Gross Vehicle Weight Rating: 2-door (GVWR)
DX, DX-G, and LX
1,645 kg (3,627 lbs)
EX
Item
Measurement
Qualification
Specification
ENGINE
Type
Water cooled, 4-stroke SOHC i-VTEC engine
Cylinder arrangement
Inline 4-cylinder, transverse
Bore and stroke
81.0 x 87.3 mm (3.19 x 3.44 in.)
Displacement
1,798 cm3 (110 cu in.)
Compression ratio
10.5
Valve train
Chain drive, SOHC i-VTEC 4 valves per cylinder
Lubrication system
Forced, wet sump, with trochoid pump
Oil pump displacement
At 6,800 rpm
52.3 L (55.3 US qt)
Water pump displacement
At 6,000 rpm
104 L (110 US qt)
Fuel required
Regular UNLEADED petrol with 87 Pump Octane Number or higher
STARTER
Type
Gear reduction
Normal output
1.2 kW
Nominal voltage
12 V
Hour rating
30 seconds
Rotation of direction
Clockwise as viewed from gear end
CLUTCH
Clutch type
Single plate dry, diaphragm spring
Clutch friction material surface area
221 cm2 (34.22 sq in.)
MANUAL TRANSMISSION
Type
Synchronized, 5-speed forward, 1 reverse
Primary reduction
Direct 1:1
Gear ratio
1st
3.142
2nd
1.750
3rd
1.241
4th
0.969
5th
0.805
Reverse
3.230
Final
4.111
Final reduction
Type
Single helical gear
AUTOMATIC TRANSMISSION
Type
Electronically controlled automatic, 5-speed forward, 1 reverse 3-element torque converter with lock-up clutch
Primary reduction
Direct 1:1
Gear ratio
1st
2.666
2nd
1.534
3rd
1.021
4th
0.720
5th
0.524
Reverse
1.956
Final
4.437
Final reduction
Type
Single helical gear
Item
Measurement
Qualification
Specification
STEERING
Type
Rack and pinion with electrical power-assisted
Overall ratio
13.73
Turns, lock-to-lock
2.67
Steering wheel diameter
360 mm (14.2 in.)
SUSPENSION
Type
Front
Independent strut with stabilizer, coil spring
Rear
Independent double wish bone with stabilizer, coil spring
Shock absorber
Front
Telescopic, hydraulic, nitrogen gas-filled
Rear
TIRES
Size of front and rear tires
DX
R195/65R15 89H
Except DX
R205/55R16 89H
Size of spare tires
T125/70D15 95M
BRAKES
Type of service brake
Front
Power-assisted self-adjusting ventilated disc
Rear (disc)
Power-assisted self-adjusting solid disc
Rear (drum)
Power-assisted self-adjusting solid drum
Type of parking brake
Mechanical actuating, rear wheels
Pad friction surface area
Front
45.0 cm2 (7.0 sq in.) x 2
Rear
28.0 cm2 (4.3 sq in.) x 2
Shoe friction surface area
Rear
57.6 cm2 (8.93 sq in.) x 2
AIR CONDITIONING
Compressor
Type
Scroll
Capacity
75 mL (4.58 cu in.)/rev.
Maximum speed
10,000 rpm
Lubricant capacity
75 mL (2 1/2 fl oz)
Lubricant type
SANDEN SP-10
Condenser
Type
Corrugated fin
Evaporator
Type
Corrugated fin
Blower
Type
Stabilized swirling flow
Motor type
220 W/12 V
Speed control
Infinite variable
Maximum capacity
485 m3 (17.100 cu ft/h)
Temperature control
Air-mix type
Compressor clutch
Type
Dry, single plate, poly V-belt drive
Electrical power consumption at 68 ºF (20 ºC)
42 W maximum at 12 V
Refrigerant
Type
HFC-134a (R-134a)
Capacity
400-450 g (14.1-15.8 oz)
Item
Measurement
Qualification
Specification
ELECTRICAL RATINGS
Battery
12 V-28 AH/5 hours
Fuses
Under-hood fuse/relay box
100 A, 80 A, 70 A, 50 A, 40 A, 30 A, 20 A, 15 A, 10 A, 7.5 A
Under-dash fuse/relay box
Light bulbs
Headlight high beam
12 V-60 W
Headlight low beam
12 V-51 W
Front side marker/parking/turn signal lights
2-door: 12V-28/5W (two filaments) Amber color
4-door: 12V-21/5W (two filaments) Amber color
Rear turn signal lights
12 V-21 W Amber color
Brake/Taillights
12 V-21/5 W (two filaments)
Inner taillights
12 V-5 W (4-door)
Rear side marker light
12 V-5 W
High mount brake light
12 V-21 W
Back-up lights
12 V-21 W
License plate light
2-door: 12 V-3 CP
4-door: 12 V-5 W
Ceiling lights
12 V-5 W
Individual map light
12 V-8 W
Trunk light
12 V-5 W
Gauge lights
12 V-LED (non-replaceable)
Indicator lights
12 V-LED, 14 V-0.56 W, 0.84 W
Camshaft
Item
Measurement
Qualification
Standard or New
Service Limit
Camshaft
End play
0.05-0.25 mm (0.002-0.010 in.)
0.4 mm (0.02 in.)
Camshaft-to-holder oil clearance
0.045-0.084 mm (0.0018-0.0033 in.)
0.15 mm (0.006 in.)
Total runout
0.03 mm (0.001 in.) max.
0.04 mm (0.002 in.)
Cam lobe height
Intake, primary
35.754 mm (1.4076 in.)
Intake, secondary A
35.358 mm (1.3920 in.)
Intake, secondary B
36.027 mm (1.4184 in.)
Exhaust
35.813 mm (1.4100 in.)
Compression
Item
Measurement
Qualification
Standard or New
Service Limit
Compression
Pressure
Check the engine with the starter cranking
Minimum
880 kPa (9.0 kgf/cm2, 128 psi)
Maximum variation
200 kPa (2.0 kgf/cm2, 28 psi)
Connecting rod
Item
Measurement
Qualification
Standard or New
Service Limit
Connecting rod
Pin-to-rod clearance
0.005-0.015 mm (0.0002-0.0006 in.)
0.02 mm (0.0008 in.)
Small-end bore diameter
19.969-19.975 mm (0.7862-0.7864 in.)
Large-end bore diameter
48.0 mm (1.89 in.)
End play installed on crankshaft
0.15-0.35 mm (0.006-0.014 in.)
0.45 mm (0.018 in.)
Crankshaft Bearing
Item
Measurement
Qualification
Standard or New
Service Limit
Crankshaft bearing
Main bearing-to-journal oil clearance
0.017-0.035 mm (0.0007-0.0014 in.)
0.045 mm (0.0018 in.)
Rod bearing clearance
0.022-0.044 mm (0.0009-0.0017 in.)
0.055 mm (0.0022 in.)
Crankshaft
Item
Measurement
Qualification
Standard or New
Service Limit
Crankshaft
Main journal diameter
54.976-55.000 mm (2.1644-2.1654 in.)
Rod journal diameter
44.976-45.000 mm (1.7707-1.7716 in.)
Rod/main journal taper
0.005 mm (0.0002 in.) max.
0.010 mm (0.0004 in.)
Rod/main journal out-of-round
End play
0.10-0.35 mm (0.004-0.014 in.)
0.45 mm (0.018 in.)
Runout
0.03 mm (0.0012 in.) max.
0.04 mm (0.0016 in.)
Engine Idle (CANADA)
Item
Measurement
Qualification
Standard or New
Engine idle(CANADA)
Idle speed without a load
A/T (in N or P position)
M/T (in neutral)
750±50 rpm
Idle speed with high electric load (A/C switch ON, temperature set to Max Cool, blower fan on High, rear window defogger ON, and headlights on high beam)
M/T (in neutral)
710±50 rpm (min-1)
Engine idle(U.S.A)
Item
Measurement
Qualification
Standard or New
Engine idle(U.S.A)
M/T (in neutral)
670±50 rpm
M/T (in neutral)
710±50 rpm (min-1)
Engine Oil
Item
Measurement
Qualification
Standard or New
Service Limit
Engine oil
Capacity
Engine overhaul
4.5 L (4.8 US qt)
Oil change, including filter
4.0 L (4.2 US qt)
Oil change, without filter
3.5 L (3.7 US qt)
Fuel Pressure Regulator
Item
Measurement
Qualification
Standard or New
Fuel pressure regulator
Pressure with fuel pressure gauge connected
380-430 kPa (3.9-4.4 kgf/cm2, 55-63 psi)
Fuel Tank
Item
Measurement
Qualification
Standard or New
Fuel tank
Capacity
50 L (13.2 US gal)
Head
Item
Measurement
Qualification
Standard or New
Service Limit
Head
Warpage
0.08 mm (0.003 in.)
Height
114.95-115.05 mm (4.526-4.530 in.)
Ignition Timing
Item
Measurement
Qualification
Standard or New
Service Limit
Ignition timing
At idle Check the red mark
M/T (in neutral)
8±2 º BTDC
8±2 º BTDC
Ignition Coil
Item
Measurement
Qualification
Standard or New
Service Limit
Ignition coil
Rated voltage
12 V
Firing order
1-3-4-2
Oil Pump
Item
Measurement
Qualification
Standard or New
Service Limit
Oil pump
Inner-to-outer rotor clearance
0.02-0.16 mm (0.001-0.006 in.)
0.20 mm (0.008 in.)
Pump housing-to-outer rotor clearance
0.100-0.175 mm (0.0039-0.0069 in.)
0.20 mm (0.008 in.)
Pump housing-to-outer rotor axial clearance
0.02-0.07 mm (0.001-0.003 in.)
0.12 mm (0.005 in.)
Oil pressure with oil temperature at 176 ºF (80 ºC)
At idle
70 kPa (0.7 kgf/cm2, 10 psi)
At 3,000 rpm
340 kPa (3.5 kgf/cm2, 50 psi)
Piston Pin
Item
Measurement
Qualification
Standard or New
Service Limit
Piston pin
O.D.
19.960-19.964 mm (0.7858-0.7860 in.)
19.964 mm (0.7860 in.)
Pin-to-piston clearance
-0.004 to +0.003 mm (-0.00016 to +0.00012 in.)
0.006 mm (0.0002 in.)
Piston Ring
Item
Measurement
Qualification
Standard or New
Service Limit
Piston ring
Ring-to-groove clearance
0.045-0.070 mm (0.0018-0.0028 in.)
0.13 mm (0.005 in.)
Second
0.035-0.060 mm (0.0014-0.0024 in.)
0.13 mm (0.005 in.)
Ring end gap
0.20-0.35 mm (0.008-0.014 in.)
0.60 mm (0.024 in.)
Second
0.40-0.55 mm (0.016-0.022 in.)
0.70 mm (0.028 in.)
Oil
0.20-0.70 mm (0.008-0.028 in.)
0.80 mm (0.031 in.)
Piston
Item
Measurement
Qualification
Standard or New
Service Limit
Piston
Skirt O.D. at 14 mm (0.55 in.) from bottom of skirt
80.980-80.990 mm (3.1881-3.1886 in.)
80.93 mm (3.186 in.)
Clearance in cylinder
0.010-0.040 mm (0.0004-0.0016 in.)
0.05 mm (0.002 in.)
Ring groove width
1.23-1.24 mm (0.048-0.049 in.)
1.26 mm (0.050 in.)
Second
1.22-1.23 mm (0.047-0.048 in.)
1.25 mm (0.049 in.)
Oil
2.005-2.020 mm (0.0789-0.0795 in.)
2.05 mm (0.081 in.)
Radiator Cap
Item
Measurement
Qualification
Standard or New
Radiator cap
Opening pressure
93-123 kPa (0.95-1.25 kgf/cm2, 14-18 psi)
Radiator
Item
Measurement
Qualification
Standard or New
Radiator
Coolant capacity (includes engine, heater, hoses, and reservoir)
Use Honda Long Life Antifreeze/Coolant Type 2
4-door M/T model at Engine overhaul
6.5 L (1.72 US gal)
4-door A/T model at Engine overhaul
6.7 L (1.77 US gal)
4-door M/T model at Coolant change
5.2 L (1.37 US gal)
4-door A/T model at Coolant change
5.3 L (1.40 US gal)
2-door M/T model at Engine overhaul
6.5 L (1.72 US gal)
2-door A/T model at Engine overhaul
7.1 L (1.88 US gal)
2-door M/T model at Coolant change
5.3 L (1.40 US gal)
2-door A/T model at Coolant change
5.5 L (1.45 US gal)
Reservoir
Item
Measurement
Qualification
Standard or New
Reservoir
Coolant capacity
0.4 L (0.11 US gal)
Rocker Arm
Item
Measurement
Qualification
Standard or New
Service Limit
Rocker arm
Arm-to-shaft clearance
Intake
0.019-0.050 mm (0.0007-0.0020 in.)
0.08 mm (0.0031 in.)
Exhaust
Spark Plug
Item
Measurement
Qualification
Standard or New
Service Limit
Spark plug
Type
NGK: IZFR6K11S
:eek:hsnap::yeahthat:
What interesting useless info. +1 though!
Yah ^ That?,
Good Job Anyway...
+1 FOR EFFORT
I love having information like this. +1 for the find.
Edit: By the way, welcome to th site:thumb:.
Thanks, I adjusted my valve lash yesterday. My exhaust was way out of wack. The car just turned 8038. I'm not so sure the quilty of honda making engines is up to par as it was in the past.
Did you notice any difference in idle smoothness after the adjusment? Was it too tight or too loose?
Still dropping trout
I am very curious as to what the dry weight of the 8th gens is though. Everything that I've read has been just over 2900 lbs, which is a huge jump from the 2550 of the 7th gen coupes.
Just a second too soon, lol. I see that honda has it listed @ right around the 7th gens now. Hmm. Now I'm a bit confused of some things..
depends on what base model. The 2dr DX is the lightest and the Si 4 door is the heaviest. I think my EX is around 2800lbs? but don't quote me on that.
1 - 20 of 25 Posts
