1 - 3 of 3 Posts
Trying to figure out what to do? Head gasket so I pulled head and sent to machine shop. Machine shop said it is warped 0.015”. There is two broken bolts on the bearing journals I need to get out And cam does not turn smoothly. I got them to face anyways because it was in the machine and was going to take home and try and polish the bearing journals a bit by hand to see if I could free up the camshaft a bit. Here are my questions?
  • what is the max amount you can take off head?
  • would this work?
  • what is the brg clearances I should be looking for?
-if this does not work is there a place to buy remanufactured head I can just throw on? Or is there an upgraded head I could put on instead ( more HP) thank you
1 - 3 of 3 Posts
