1 - 4 of 4 Posts
There are a few pretty good videos and writeups about rear shocks replacement, and it seems a pretty doable DIY. Planning to do it this Saturday as one of the shocks is leaking badly.
Just have an amateur question: Once you unscrewed and removed the old shock, is there a risk that the spring will fly out? Obviously it's under pressure, just concerned if it can cause any damage..
Once you have the car jacked up and the wheel completely off the ground the spring shouldn't really be under pressure any more. The spring might fall out, but I think it should just stay in place on its own. You should just be able to unbolt the old shock and swap in the new one.
Like SiBurtonGuy said, once you jack it up and take the load off it's all good.
The only time be to worried about flying springs is when taking a shock apart to replace springs AFAIK.
Also, an alignment isn't a bad idea after messing with your suspension.
1 - 4 of 4 Posts
