1 - 10 of 10 Posts
Got my subframe pulled today, thought that was a good place to stop, till my clutch comes in. I had one from autozone, but the pilot bushing was bent, so I ended up returning it
242587
Then I will pull the passenger side half shaft, driver side cv axle, undo the trans/motor mount and undo the bell housing and drop the trans.
My clutch probably won't be in till early next week, also got energy suspension bushing for my lower control arms.
Aye aye aye, almost about had an aneurysm earlier, trying to get fly wheel off of the crank with a 1/2 drive 17mm 12pt socket and swrench, and ONE bolt stripped.
Did some reading, and ended up getting it out with some heat and an old (not as useless as I thought) impact gun.
Discussion Starter #6
Got my k20R flywheel from the shop, noticeable difference in weight from the beefy stock one.
My only concern is I'm not tuned or flash, am I going to throw any codes? Can't seem to find a straight answer anywhere.
242595
You might wanna look into replacing the main seal while you're at it.
I had to take tranny back off to replace it right after replacing clutch.(Started leaking as you can see)
You dont have to but, headsup on your mileage.
242598
Discussion Starter #9
I thought about it, but I thought mine looked alright though,
and I've heard if it looks ok, not to go messing with it. I'll post a picture
Discussion Starter #10
Imo it likes like it might've already been done at one point.
I pulled an exedy clutch out of the car, I know they make the oem clutch, but does it have their name on it? If not, then the clutch has already been replaced. There's 128xxx on the car
242600
1 - 10 of 10 Posts
