1 - 15 of 15 Posts
Well today my car's battery died so i got jump started, and i notice some of my lights inside dont turn on, and my driver windows doesn't do the automatic function of going down with one push of the button. Could some fuses blown? any help would be nice. thanks
Discussion Starter · #7 ·
yeah i fixed the window but at night when i turn on my headlights my vsa switch doesn't light up its all dark in the corner switch.
Maybe it is just that the illumination bulb has failed ?? Is it the only one not lighting ??
Some have the T series replaceable bulb/socket assemblies.
The illumination bulbs are a bulb and plastic base assembly.
The bulb goes into the side of the switch, twist base left to remove.
They run quite hot and have always been prone to failure over the years in the Civics (most likely others that use them as well)
Discussion Starter · #13 ·
Ok makes sense now. Thanks for all the info helped a lot. Quick questiom if I take it to the dealer would they fix cause I need to also get my clicking clutch fixed?
It would be costly for the dealers labor if out of warranty, you might want to ask for an estimate. Part is around $4
1 - 15 of 15 Posts
