1 - 7 of 7 Posts
Hello all, this is my first post and was wondering if any of you knowledgeable members have any insight to my problem
This evening I lost all of my power steering fluid at once. I will try to see what went wrong tomorrow with some daylight. My question would be, is it possible to bypass the power steering pump on my 2007 civic dx without a/c. A shorter belt maybe? I’m not looking to spend money on the car as it’s my winter ride while the 10th gen SI is parked.
Thanks in advance for any input.
Looking at some diagrams the PS pump is the rear most pulley. The only way I see it working is if the belt runs from the crank pulley to the alternator. The tensioner pulley would then press down on the belt. I don't know if it has the range to get enough tension on the belt.
To get a new belt length just route some string how the new belt would go and then measure it. You can buy a belt that is close to the needed length and try fitting it up. If it doesnt work then just return the belt.
241905
Honestly the problem is probably a hose has burst. Luckly the parts are really cheap on rock auto if you are willing to replace them yourself.
Thanks for your feedback and diagram. I replaced the power steering rack a few years ago. So I too am hoping it’s just a hose. It started at as a drip leak on my brand new driveway and then a complete burst just before I did the maze drivethru at McDonalds, that was fun!
To get a new belt length just route some string how the new belt would go and then measure it. You can buy a belt that is close to the needed length and try fitting it up. If it doesnt work then just return the belt. View attachment 241905
If you don't give a dam just drive it without the fluid in it. Everything stays the same, pump wont work after a while but i know someone personally 4 winters in with no fluid in his system, its a straight beater though
I 100% don’t give a damn. I’ll go without the power steering. I’m was just concerned about the internals of the pump burning up and blowing up the pulley and subsequently losing the serpentine belt
I found the cause. Turns out it was the Steel return line that sits on top of the subframe beside the rack. A small pin hole. 10 dollar hose from local parts store
thanks for your input
1 - 7 of 7 Posts
