1 - 10 of 10 Posts
Okay guys I just noticed it today but sometimes when I go over bumps or or turn to the left I get this loud popping noise now It doesn't do it all the time and not when I go in a straight line..it does pull slightly to the left It's kinda like the suspension is bottoming out. I only have about 525 miles on the car you think the work would be warranty or would I have to come out of pocket ? I have a appt with Honda on Tues
Maybe this?:
http://www.8thcivic.com/forums/showthread.php?t=48734&highlight=popping
Clutchmaster said:
I think that's it I was like WTF!!! the only thing is my Car is an 07
You may be covered:
VEHICLES AFFECTED
2006 Civic 2-Door Si – ALL
2006 Civic 4-Door:
From VIN 1HGFA1...6L000001 thru
1HGFA1...6L137665
From VIN 2HGFA1...6H500001 thru
2HGFA1...6H528035
2007 Civic 2-Door EX A/T:
From VIN 2HGFG128.7H500001 thru
2HGFG128.7H500056
2007 Civic 2-Door Si:
From VIN 2HGFG215.7H100001 thru
2HGFG215.7H100199
I have the same problem, 07 Si Sedan with the same popping noise, which is not listed under the TSB. You have any luck getting Honda to fix it?
Discussion Starter #7
yeah I had no problem they replaced the whole front suspension fo free!!!!!
I had that same popping noise, I have an 07 si coupe and my VIN wasn't inculded in the TSB. HOwever the service guy at the Honda dealership I go to (Formula Honda in Scarborough) swapped out the bump stops. No more popping, however I do hear a different noise now every once in a while when going over a deep pothole....not sure if this is my shocks bottoming out?
it is the hydraulic motor mount I promise... Just have them replace that.
1 - 10 of 10 Posts
