Hello Everyone,
Recently bought a 2009 Fg2. Decided to go with the Skunk 2 Alpha headers. After Installing them I realized that the primary o2 sensor is abutting the shift linkage. I also installed the Hasport 70a. Has anyone else had this issue and if so are there any remedies? Thank you!
Hmm i have an 08 and my header brand is megan racing so they are different but is there a way to bend the linkage bracket over a little or possibly adjust your exhaust hangers so they arnt on top of each other? Im surprised S2 designed the header with the bung directly across from that linkage.
Discussion Starter · #4 ·
Thanks for the reply. I was also surprised I have seen videos of these installed and no one has mentioned this issue. I wonder if the o2 bung was welded slightly off. I might contact skunk 2 for advice.
hmm i stalled the same motor mount but i dont belive i lined the engine up in the front correctly. i took the front mount bolt out to get the rear one in but now the end of my header pints up and my exhaust leaks att the donut gasket. i think i need to loosen it position the engine with a jack the torqu the bolts down again maybe that might work for u too
