1 - 3 of 3 Posts
Hey guys i have a 07 civic si and a couple of weeks ago I changed my driver side cv axle joint. Brought the car down started driving and noticed there was a significant amount of play in my steering. So i thought it was my inner tie rods.So i ended up changing my inner and outer tie rods. I then brought it to get an alignment and it still had some play in the steering. I then jacked the car up and shook the tire left and right and it did move a little. Is the something wrong with my rack and pinion. Or eps?
Maybe rack and pinion is lose just my guest. I have to check this as I have play and a poping noise when I turn the wheel all the way from one side to another.
Also I believe to check the rack and pinion bolts your going to either have to drop the sub frame completely or just a little by loosening the bolts but not all the way out.
1 - 3 of 3 Posts
