1 - 9 of 9 Posts
· Registered
On my 08 Si, when i turn on car and drive off, door lock by it self both driver and passenger. Now when i turn off car only driver side door unlocks, aint it supposed to unlock both? the lock unlocks with the button but only driver side unlocks when i turn car off. If its not normal, what can i do to fix problem?
· Registered
omg, you can actually get the passenger door to unlock upon turing the car off? i never knew, i always hit the unlock button to let my passengers out. it was so annoying. i guess i found someting to do on lunch tomorrow! glad i found this thread..thanks guys
· Registered
turn ignition to on position (not when engine is running) then hold down the unlock button until you hear it unlock 3 times (takes a while) then all 4 doors will unlock when remove key from ignition
· Registered
that sir did the trick for me. the only thing that threw me off were the directions in the owners manual...it talks about putting the car into drive while doing this for automatics. it had me thinking that you couldnt do this to a manual car. but it worked out. thanks guys
1 - 9 of 9 Posts
