1 - 10 of 10 Posts
Hi all.
I need your help.
I have 2008 civic with an R18a engine and have been experiencing some problems with the car.
I took the car for a service this month (I bought it in august) and when I received it back I noticed a flat spot in the acceleration.
The car was peppy before this and now between +/-1500 rpm-2500rpm, it would bog completely and then pick up acceleration again (still slower than before service).
I then cleaned Maf and throttle body and completed idle re-learn but ended up with an idle of 1000RPM and bogging persisting along with rough idle.
I then asked the shop to reset adaptations (throttle position etc ) and now the car is even worse. The idle has come down but the car struggles horrendously to accelerate in all gears and seems to accelerate better at partial throttle compared to full throttle, please help, I'm at my wit's end and I don't know what to do.
Time Line
  1. The car went for a service (battery unplugged I assume).
  2. Developed flat spot in acceleration 1500-2500rpm.
  3. I cleaned Maf and throttle body.
  4. Completed an Idle re-learn.
  5. The car developed a rougher idle and high idle of 1000rpm.
  6. Asked shop to reset throttle position and they also reset other adaptations like spark/timing (not exactly sure)
  7. Car behaves even worse and struggles to accelerate in any gear, engine note changes at WOT and car accelerates better at partial throttle depression (still poor).
  8. Car chokes and bogges and idles extremely poorly, can't keep up with traffic/climb hills and take turns safely due to lack of power.
Symptoms
  1. Poor idle.
  2. Heavy fuel consumption 14l/100 km (foot is almost flat at all times to keep moving at normal speed).
  3. Bogges at WOT.
  4. Engine note changes at WOT (struggles and feels like its just dumping fuel).
  5. lack of acceleration.
  6. Have to slip clutch excessively to get started.
  7. Horrible vibration at idle.
  8. Accelerates better at partial throttle compared to WOT.
  9. No codes.
  10. No check engine light.
Tests
  1. Maf is good as car cuts out when it is removed.
Please help, I was so happy with the car before service , not sure if I just need to remap it or If the answer is simpler.
I would check your spark plugs and spark plug wires and make sure they are gapped correctly, make spark, and that the wires aren't near grounding anywhere (such as the rubber insulator isn't melted and wires exposed). This could possibly cause what you are explaining.
Clearly, whoever serviced your car should fix this but you have already been there twice. You didn't mention what service was initially performed. Hopefully service was not received at a Honda dealer. Maybe another Honda dealer could help. I know my suggestions are not much help. Sorry. :sick:
Discussion Starter · #4 ·
Thanks for the advice, I genuinely appreciate it.
do you think if they replaced the original spark plugs with a cheaper variant, that it could cause what is happening currently?
Went back and the company who serviced the car said they don't know what is wrong and suggested a tuning company.
I will probably visit a honda workshop on payday if I can't get it sorted before then.
I believe NGK iridium spark plugs are specified for a 2008. NGK website shows part number as IZFR6K-11S. These plugs come pre-gapped at .044”. I have read that use of other spark plugs is not recommended and can cause performance problems. Be advised my 2008 still has original spark plugs and I have no personal experience changing them.
Wrong spark plugs could cause the problem, but I am more thinking of a spark plug wire grounding out and not sparking hence you might be running on 3 cylinders instead of 4, could be brought up at full throttle as the time the spark is activated has a shorter wait period between.
This line "...the car struggles horrendously to accelerate in all gears and seems to accelerate better at partial throttle compared to full throttle" would indicate a problem related to fuel starvation.
Check the fuel delivery pressure, blocked fuel filter and the fuel pump itself.
The only thing that makes me question that it's a fuel problem is because he said the car consumes a large amount of fuel, my thought was the car was pumping a lot of fuel but maybe one of the other 2 parts to combustion was lacking. He said the car was getting around 16.8mpg which is definitely not normal even with a heavy tune
1 - 10 of 10 Posts
