From here:
http://www.8thcivic.com/forums/civi...uality-screw-rocks-screw-me-not-avoiding.html
"same exact thing happened to my Si...big ole paint chip right on the edge of the hood...
i bought some touch up paint at the dealer (about $10), used the brush it came with just to dab a small drop onto the chip, make sure you clean the chip thoroughly!!! then let it dry for a half hour (the paint will actually "shrink", meaning the drop you just put on will be much smaller when it fully dries). You will repeat this process a few times, the trick is to go SLOW and do NOT be impatient.
ALSO, the real trick i used that no one else I have read on forums has done is, on the very last application put a piece of clear tape (like the small tape dispenser tape, not packing tape) completely over the chip and fold it down over the edge of the hood so the paint will dry nice and flush with the rest of the paint. Put the tape over the paint about 5-10 minutes AFTER you applied it so that the paint isn't too wet or too dry (the paint is actually a little malleable after a few minutes and you can "move" it around a little in the chip). When you remove the tape (give it about an hour or so) the tape will come off clean with no paint residue at all and the new paint will be nice and flush and shiny! Good Luck!"
