Hi all,
my battery is draining overnight at a rate of 500 mA. by looking into the fuse box and other things i figured out the following
- both Fi- main relay and Ignition coil relay are closed even when ignition is off and key is removed
- it is a ground signal coming from A6 pin out of ECM is triggering both relays
- there is no short between relay ground and body ground
- when i remove connector A from ECM, relays are not triggering
