1 - 1 of 1 Posts
shopping for that perfect gift? or just making christmas wishlist for yourself?
we have created an affordable list of products that are great as "stocking stuffers"
type one racing lug nuts
only black and blue are available
set of 16 lug nut
christmas special....$125.00
passwordjdm tow hooks
cnc machinced from aircraft 6061 t6 aluminum
black, blue, gold, purple, red & silver
christmas special....$120.00
blox racing spherical shift knob
-cnc machinced from high-grade steel
-custom weight 142 or 490 grams
christmas special....$65.00
skunk2 shift knob
made from stainless steel featuring a gun-metal finish. each shift knob is custom-weighted to 440 grams. when used in conjunction with the skunk2 racing short shifter, the combination provides the ultimate in positive shift engagement. approx. 440 grams
available in 5 speed or 6 speed
christmas special....$60.00
skunk2 06-08 honda civic short-throw shift adapter
christmas special....$50.00
skunk2 magnetic oil & transmission plug set
skunk2 magnetic drain plug set includes both engine and transmission plugs to help extend engine life by removing harmful metal particles from your engine oiling system thus prolonging bearing and transmission gear life. skunk2 magnetic drain plugs are designed to racing specifications and feature lightened bolt heads that are cross-drilled for use with safety wire. skunk2 magnetic drain plugs are easy to install and can easily be cleaned after each oil change. fits all honda, acura, mitsubishi, ford, and gm manual transmissions. may fit some automatic transmissions but it is the owners responsibility to determine if product will work for their specific application.
christmas special....$35.00
skunk2 radiator cap
the skunk2 radiator cap increases internal radiator pressure, thus physically raising the coolant boiling point and increasing cooling efficiency.
Skunk2 Racing’s Pro-Series Intake Manifold
2002+ K20A,K20A2,K20A3,K20A1,K24...............$610.00
K-SERIES THROTTLE BODIES
70 mm Billet Throttle Body - K Series..............................$450.00
Skunk2 Composite Fuel Rail
Composite Fuel Rail K20/K24.............$245.00
Composite Fuel Rail K20Z3................$260.00
Skunk2 MegaPower R exhaust systems
• Optimizes Usable HP and TQ
• Ideal for Highly Modified NA Vehicles
• Ideal for Turbocharged Vehicles
• JDM Super N1 Styling
• Optimized Free-Flow Design
• Oversized Tubing
• Super Low Restriction Oversized Muffler
• Robotically TIG Welded
• T-304 Stainless Steel
• Precision CNC Mandrel Bent
• Includes Removable Silencer
70mm 06+ CIVIC Si Coupe..........$660.00
70mm 07+ Civic SI 4-door...........$660.00
Skunk2 MegaPower Header
The Skunk2 MegaPower Header is designed and engineered to maximize exhaust flow and increase both horsepower and torque throughout the entire RPM powerband. Our unique design is the result of over a decade of racing experience coupled with computerized modeling and extensive dyno testing. Each Skunk2 MegaPower Header features equal length, sequentially-paired, stepped primaries and a 4-2-1 Tri-Y design with a 2.5 inch collector. These features coupled with our unique design specs provide an extremely broad powerband that can be used on a wide range of engine sizes and configurations. Each header is constructed from T-304 stainless steel with fully polished, mandrel-bent tubing and a CNC-machined flange for added strength and durability.
MegaPower Header: 06+ Honda Civic Si................$970.00
1 - 1 of 1 Posts
