This special is only for East Coast Canada
T1R 70R Dolphin FD2/FA5 796.00 CDN
The best exhaust you can get to make the most horse power for your Honda K20A engines. From our testing, we found 70mm piping is the most suitable pipe size to increase the engine power dramatically for K20A engines. Special CAT-BACK 63mm joints to 70mm for extreme exhaust flow efficiency. Track proven, extreme durable and made with SUS304 aircraft stainless. Compatible for N.A. and F.I engines.
T1R Power Header 796.00 CDN
The stock header is the most restrictive part of the exhaust on the K20A engine. We have been spending years of effort to develop a header with longer 4-2 conjunction to obtimize torque and hp across the power band. Finally we have come up with a 45mm piping size for primaries with 65mm pipe for collector. The 4-2-1 design with the special "Power Neck" is to improve exhaust efficiency other than increasing volume. All exhaust tubings are 1.2mm thick to reduce as much weight as possible while maintaining a strong enough structural design to with hold the heat and stress caused by the engine. The header replaces the stock 4-1 portion and the stock catalytic converter. This header was developed and intended for race and track use only. Dyno tested 15+whp gain.. This header was developed and intended for race use only. T1R O2 Fix (mechanical O2 smulator is equipped with this header).
T1R Racing convertor 180.00 CDN
For maxiumum exhaust flow and power gain, the stock catalytic converter must be replaced with a free flowing test pipe. T1R offers the Racing Converter, a high flowing non-resonated test pipe designed for racing purpose only.
Comes with T1R O2 fix to eliminate CEL and brackets to fit the stock heat sheilds off your stock catalytic convertor.
T1R rear camber kit 320.00 CDN
Introducing the T1R rear adjustable upper arm also known as the rear camber kit, designed with the ability to adjust positive and negative camber up to +/-5~ degrees. With this amount of adjustability, it improves the life span of your tires by reducing uneven tire wear and increases your vehicle’s handling dramatically.The T1R rear adjustable upper arms are made from forged T6-7075 aluminium offering the lightest weight design. In addition, these units are also crafted with the same forged aluminium on the arm ends along with polyurethane bushings. Due to the fact that most adjustable upper arms have forged aluminium Body but steel arm ends, the T1R design take advantage with this lighter weight design. Aluminum T7075 was used for increase in strength and durability against breakage Under extreme conditions.
T1R Crank pulley 155.00 CDN
The T1R high performance light weight crank pulley has been developed to reduce drive-belt stress and rotating mass thus allowing a smoother engine response and acceleration which offers an increase in horsepower and torque.
This crank pulley has been designed to factory OEM sizing due to the disadvantages with underdrive pulleys (smaller sized pulleys) which causes damages and malfunctions to the alternator. Smaller sized crank pullers are very prone to charging and battery issues due to being underdriven.
Made out of CNC machined Forged aluminum and the pulley weighs on 649g (1.42 lbs).
T1R Brakelines 119.00 CDN
Everytime when you apply pressure to the brake pedal to slow your car, some of the hydraulic energy is wasted expanding the stock rubber brake lines. Effective braking power is decreased. This is also the cause of the soft feel some cars exhibit at the brake pedal. As the lines age, the softness increases. This "line swell" is virtually eliminated using high quality Techna Fit brake lines.
These lines are constructed of high-grade teflon, wrapped with stainless-steel braiding, and finished with a clear protective sheath. Meets D.O.T. Standards.
T1R Big Brake Conversion 1999.00 CDN
T1R offers CNC forged aluminum twinblock brake calipers with staggered pistons (38.1/41.3mm) to improve initial, controllability and hard braking at all speeds.
Heat treated steel angle slotted rotors with duraluminum hub (floating disc design) are used for excellent heat dissipation and extreme durability while keeping weight down as much as possible. Special street compound (low dust) brake pads are quipped to serve performance from street to track.
1. Pricing is subject to applicable taxes
2. 50% deposit required
3. Limited quantities, while supplies last
