It's mostly kids who are missing shifts, you can see a few videos online of kids 'racing' and doing it and it's usually the 2-3 upshift, and they are 'WOT shifting' which means you keep your foot on the gas and punch the clutch and shift quick.mininsx said:^ well, you answered your own questions mostly...
Dont be scared, just let the shifter do its own work. 1-2 thats easy, 2-3 coming out of 2 it wants to go to nutral right under 3, 3-4 straight back. 4-5 up, to the right and up again, 5-6 hold her to the right and slide her right back...
The shifter doesnt need much input to do its job correctly, I think the problem is with grab happy people not paying attention to what they are doing...
The transmission will not grind from 3 to 2 with the clutch in. The transmission will not let you go to reverse and it is very tough to go into 1 after you've sped up. A 4 to 1 or a 2 to 1 mis-shift is pretty much impossible in a honda...
I didnt understand it either, I figured the rev-limiter would do something, but its too much for it to handle...
Someone else feel free to buz in and help me here, I'm not the best at explaining my self sometimes...
But please dont be scared to drive a honda manual. They are the best, and they are a pure pleasure to drive. You feel really connected to the car...
no, you're referring to the "money shift" or a "mis-shift".mininsx said:When your hauling a$$ and you shift from 3rd into 2nd(instead of 4th) on accident and your motor blows...
AKA Mis-Shift...
no. skip shifting and mis-shifting are two completely different things.Chris3k2 said:oh, i didn't know that was another turn for mis-shifting. lol i feel really dumb now cause i own a 5 speed 2k1. haha well whatever.
what happens is this....jp375 said:I'm still confused on how you can blow your motor going into the next lower gear, I'm assuming your at the top speed range for 3rd gear and then you drop it down into 2nd and the revs shoot up because the car is going too fast for the gear, the couple of times i have driven a manual it didn't seem like the transmission would let you do this. When you go to downshift from 3rd to 2nd and your not in the right range doesn't it just grind and not let you put it into an incorrect gear? Obviously I don't know jack about driving a manual, some more insight into this would be helpful. I want my next car to be a manual, but its stuff like this that scares me away...
Hmmm, the way the original posters posted, I mis understood them to be talking about mis-shifting...S2000man01 said:no. skip shifting and mis-shifting are two completely different things.
Very well put! This is how i drove my RSX-S, hand on the right 1-2, hand on top 2-3 and 3-4, hand slightly on the left 4-5 and 5-6...S2000man01 said:what happens is this....
you are winding out 3rd gear and reach the redline. you go to shift, and the most COMMON newbie mistake is grabbing the entire shifter with your hand on the side. since i can't think of a better way to describe it, your hand placement is as if you were going to grab your shifter and jack it off. lol.
when you do this, and go to put it into 4th, people have a tendency to PULL the gear towards them while also going to 4th. this causes you to actually put the gear into 2nd.
since you are redlined at 3rd, and go into 2nd, this causes a mechanical overrev, forcing the engine beyond the rev limiter. (rev limiter WILL NOT prevent this). this makes the engine go well into an rpm range it was not designed to do and often causes piston to valve contact, which will pretty much have the same effect as tossing a grenade into your engine. this has even caused rods to be thrown clear through the block.
in order to prevent this, you should put your hand ON TOP of the shifter while it's in 3rd. then simply use your fingers to push the gear straight back.
