1 - 7 of 7 Posts
Alright just did a plug change on 2010 civic 1.8. While changing them notice number 2 had oil on the plug. Haven't had any misfires till 2 days after . I put ngk plugs back in. Anyway everything I've looked up shows nothing on the 8th gen atleast what I can find. I'm figuring they have O rings under the whole rocker arm assembly like the older Hondas but I could be wrong. Any help would be awesome.
Thanks,
2010 Civic
This is no help, but I just inspected and replaced my spark plugs because my car has been burning quite a bit of oil for the past couple of months. It burns up to one quart in 500 miles, sometimes nothing between fill ups (not usually).
2010 Civic
My 2010 Civic has 136,000 miles and has worked well for me. When I changed my plugs there was oil inside the spark plug tube of number 2. The burnt oil was also on the igniter tip. I could see burnt residue on the top of the piston. I am not sure what the root cause of all this goings on. I have read that the piston rings might be sticking or the valve guides are letting oil in. Why there is oil above the spark plug is a mystery to me. It could be that the spark plug gasket leaked the oil that is burning in the cylinder. I don't know
Thank you, I just joined
2010 Civic
Your spark plug tube seal is leaking. Watch on You Tube "Replacing the valve cover gasket and spark plug seals on a Honda K20 motor". The other source of oil might be at the bottom of the tube.
2010 1.8 L Honda engine's spark plugs do not go through the valve cover. Maybe the valve cover is leaking and entering the spark plug tube below the valve cover, but I have not seen evidence of that.
2010 Civic
After changing the spark plugs and cleaning the plug tube, I drove it for a day. When I got back home, I pulled the wire and saw oil was leaking in an one eighth inch, very light, stream down the tube from the nut. I used a 1 1/4" socket to take the nut at the top of the tube off. (I did not have a metric size socket but they are very close.) I cleaned the washer and all the area, re installed the large nut. Then I drove over 100 miles and checked the tube again. There was no oil. I will check again after another couple of days. The engine is running better for now.
1 - 7 of 7 Posts
