1 - 4 of 4 Posts
· Registered
So a couple weeks ago my lower radiator hose popped off. a couple days later I noticed brown gunk under my car and turned out to be oil mixing in my coolant, from where? not sure. So pulled the head off and checked out the gasket, no cracks. the head is at the machine shop seeing if it was warped or not.
Has anyone else had any problem like this??? Ideas are up in the air right now
btw my car:
SI with K24
· Registered
Discussion Starter · #4 ·
i ended up having the head resurfaced and it was off .004", so warping, it did not have coolant in the engine just oil was traveling into the water system, and everything ran perfect (weirdly). reinstalled it and was good for about 4 days. and then it happened AGAIN but worse and I was overheating... engine is being pulled apart right now, thinking there's a hairline crack in the block
I'll update as I get info
1 - 4 of 4 Posts
