1 - 19 of 19 Posts
ok i have the sandwhich that came
wit my used kit and i wasnt sure what it was so thats why i asked. does this replace the banjo bolt set up?
is an oil filter sandwhich a better set up? it came wit my kit so mite as well use it lol
The filter sandwich is just for the feed line, if you have then use it. You still need a oil return line and tap the oil pan to do away with the fail banjo fitting.
Discussion Starter #7
im runnin the banjo bolt for a couple weeks since im in a rush to get the kit on which its apart now and kits gonna go on tomorrow. only rushed cuz a shop i trust is backed up for a lil while..and i dont have the guts to do it myself so im runnin the banjo for now..how hard do u think itll take the shop if everything is installed?
Discussion Starter #9
ok sounds like that gonna cost me a billion dollars only if i had the guts to do this myself...hopefully i wont leak to much and my banjo bolt wont snap on me.
If your mechanically inclined its not that bad. I dropped my subframe when i did the clutch, it was a lot easier then i thought it was going to be.
Discussion Starter #11
yea but for some reaosn droppin the subframe and drillin a hole in my oil pan makes me so nervous..not being a little girl but you know hopefully ther banjo stays put till i can afford the fitting and such
Discussion Starter #13
no sir i was always a basic bolt on and drive it as it is kinda guy till now but ill have to do it on someone eles is car instead of mine lol
you'll probably spend more on a good drill bit and tap than you would spend if you just brought it to a shop to have them do it. or ask a friend with a lot of tools, like my friends always do to me lol
Discussion Starter #15
you think so? i think it safer for my anyway to bring it to a shop since i have no cluee where to start but that not a major issue as or right now i was just wondering.
depends on the sizes, but a 45/64 (going off the top of my head, i believe thats the correct size bit for a 1/2" tap) drill bit and 1/2" npt tap can cost about $50. then you risk the chance of messing it up.
Discussion Starter #17
yupp....messin it up could put me careless for a little bit ill take the chance of runnin the banjo bolt for now till that shows me major issues.
1 - 19 of 19 Posts
