ok here you go, i did an oil change over the weekend with a friend, didnt take many pictures but its actually a lot easier to do than the dealers and jiffy lube would like you to think.
What you will need:
4 quarts of 5W20 oil
Honda oil filter or equivalent from local parts store
Drain plug crush ring from dealer or parts store
17mm wrench to remove oil pan drain plug
oil catch pan
oil filter wrench
Papertowels
Rubber gloves (optional)
This is best done when the car is somewhat warm
1. Get your car up in the air (use your method of choice here, car lift, ramps, or jack and jack stands (DO NOT GET UNDER THE CAR WITHOUT PUTTING ON THE PARKING BRAKE AND USING JACK STANDS!) my friends dad has a shop so we used a lift, normally i would use ramps in my driveway.
2. Pop your hood and open the oil cap on the top of the engine, this allows the oil to drain more easily.
3.
The blue thing is your filter, honda actualy molded Engine Oil into the bottom of the pan and ive circled the drain plug bolt
from the back
Under the car, position the catch pan under the drain plug, the oil will shoot out a bit so make sure theres plenty of room. At this point i like to make sure the paper towels are handy and i have a rubber glove on. use the wrench to loosen the drain plug so you can remove it by hand. the oil will start to drip as you remove it. Since the oil temp can be hot i like to have the glove on so i can quickly get the hot oil off my hand.
4. use the oil filter wrench to loosen the oil filter and then remove it by hand. it will drip on you as you remove it so be ready for that.
5. dip a finger in the old oil in the catch pan and run it around the rubber gasket to moisten it and make a better seal, put on the new filter by hand and then give it about a 1/4 turn with the wrench, do not over tighten the filter, the threads could strip.
6. Remove the old crush washer from the drain plug and put the new one on, re-install the plug with the 17mm wrench, this one you can tighten up because you are crushing the aluminum ring slightly to create a seal.
7. Pour the new oil into the top, i suggest using a funnel to make it easier. The car states that it takes 3.9 quarts of oil, so you can safely put all 4 quarts into the engine.
8. Run the engine and make sure that the oil light goes out, check the dipstick to make sure the oil is at the appropriate level. check for leaks under the car.
Resetting the Oil Life Meter:
9. Press the sel/reset button untill the oil life monitor comes up, hold the sel/reset button for 10 seconds, the oil life will start to blink, press and hold the sel/reset button for 5 seconds to reset the monitor.
You're done, hope that helps
A Si Supplement:
http://www.8thcivic.com/forums/do-y...-diy-supplement-si-oil-change-noob-style.html
What you will need:
oil catch pan
oil filter wrench
Papertowels
3.
from the back
A Si Supplement:
