I have a non-navi premium sound Civic SI.
I am looking to do an extensive stereo install. I say extensive as I am a n00b when it comes to wiring and stereo which I shy away from...
I am doing the following:
- Pioneer double-din
- Axxess steering controls
- Sirius XM module
- Pioneer Mirrorlink module for my Android phone
- DVD bypass (just for grins, really)
- Also doing a redline shift beeper so I don't overrev.
I have read a lot of threads and used a lot of it to help guide me. But, I still have some questions which I will list here in hopes someone can help. I have noticed some users like bruple who seem to be genuises in wiring.
Wiring Harness: I got the Scosche HA13B harness as I would like to integrate the factory amp as I would like the sub and tweeters to work and I don't think the factory system is that bad and I am ok with the sound it puts out. I would just like more features like bluetooth, siriusXM, back-up camera and such.
Anyways, The 1st thing I did was re-pin the secondary harness since its well documented here that all the 5 pins are wrong.
Are the RCA's for aftermarket amps on the HA13B harnesses? Or does the factory amp use them?
Wires I know I have to wire into the Pioneer harness:
Yellow – 12V Constant
Red – 12V Accessory
Black - Ground
Orange with White Stripe – Positive Illumination Wire
Orange with Black Stripe - Negative Illumination Wire (Must be Grounded if connecting Orange with White Stripe)
Blue with white stripe: Amp turn-on
Some of the wires I don't know if I need since I have the RCA's:
Green – Left Rear Speaker (+)
Green with Black Stripe Left Rear Speaker (-)
White – Left Front Speaker (+)
White with Black Stripe – Left Front Speaker (-)
Purple – Right Rear Speaker (+)
Purple with Black Stripe – Right Rear Speaker (-)
Gray – Right Front Speaker (+)
Gray with Black Stripe – Right Front Speaker (-)
Pink - K-Line for Off-Board Communication
Black with White Stripe - Security System
Green with White Stripe - Vehicle Speed Wire - I don't know if I need this for DVD bypass?
Brown - Mute?
Also, I need a tach signal in the car for my redline beeper, is there any place I can pick this up in the car?
Or do I have go into the engine compartment straight off the ECU? I believe its a green wire?
Or I could go off the coil? What color wire is it on the coil?
I appreciate any and all help. I will ask more questions, probably!
Thanks!
- Sirius XM module
Red – 12V Accessory
Black - Ground
Brown - Mute?
Thanks!
