Well, I now understand why no one could help with my BCM problem. I located the BCM under the dash on the drivers side, RHD that is. It is forward of the fuse block which needs to be removed to access it, this in itself is a total ball ache. Then the module is located on a metal plate and is secured by four screws, one in each corner and have clearance of about 2cm from the car body, at this I despaired
but all was not lost, the plate or mounting bracket had 2 visible10mm nuts which were removed, one with great difficulty, and as I secured purchase on the second one, I was thinking,"Yes, cracked it!" but no, the mounting bracket was as secure as ever
.Where the rest of the securing nuts are, I will never know, because I am no taking the dash out!!! So it was built back up and I still have the problem of no sidelights. I can only think of rigging a remote sidelight switch to front and rear sidelights, can anyone direct me on how to do that? Many thanks, Rod.
