1 - 6 of 6 Posts
For the past two months my FG2 has been sitting because my car suddenly lost clutch pressure and I wasn't able to put it into any gear. The car moves forward and jerks when I start it in 1st gear, so i'd assume that the transmission was ok.
A week goes by, I replace the clutch master, Slaver Master, clutch line, and a new clutch and flywheel.
I attempt to bleed the clutch, and it still doesn't bleed. No matter what I do it still would not bleed. I've tried a converted Clutch master (EM1) and a new OEM clutch master from Honda and I'm still not able to bleed the clutch, I'm stumped and spending money.
I've been looking all over this forum and finally made the courage to create an account and try to see if anyone has been in my situation and was successful.
Dop3st1 is online now Add to Dop3st1's Reputation Report Post
Hey buddy you have air in the master most likely you have to preform a bench bleed take you master and slave back out and bleed it that way.......also if you did the em1 upgrade did you change the rod and washer piece....if you changed the washer piece with the oem one the tabs are pushing it down to far and stoping the fluid from coming to your slave.....once theirs air in these masters it’s a *****...you have no pressure because of your slave and master...take it back off and bench bleed...also put the washer back on that came with the em1 cmc but keep the oem si rod on
I recently bought a hybrid racing cmc and clutch line...but right now I have a 26$ master from advanced on and all I did was switch the rod and piece that connects the peddle.... I was having the same issues as you.....also check your clutch line make sure theirs no kinks on leaks make sure everything is tight
Had the same exact issue last month. Clutch lost pressure instantly one time and couldn't get into gear. Turns out I had lost all fluid from a leak. Here are my thoughts. You've probably already addressed most of these, but this will also be helpful for those who are new to any of this, so it's best to have all bases covered.
1. For the master cylinder:
Check for leaks where the hardline connects to the master cylinder (and make sure it is nice and tight), and ensure the small rubber gasket for the outlet port is new (don't reuse the old one). Also check near where the piston connects to the pedal inside the car to make sure the piston hasn't leaked any fluid onto the floor/firewall insulation.
2. For the hardlines:
Check where it connects to the rubber hose that loops under the brackets attached to the frame and the bell housing, leading to the slave cylinder and make sure it's not leaking either where the hardline itself is seated into the connection, or where the screw fitting itself is leaking (so you'll either have the hardline improperly seated, or have cross-threaded the screw fitting. Both will give leaks).
3. For the slave cylinder:
Same for master cylinder, except make sure bleeder valve is secure and tightened by hand tools, not by hand alone (made that mistake and sprayed fluid everywhere one day). Also check that the rubber boot covering the piston is not leaking.
4. For bleeding the system:
Press in clutch and keep it pressed in, open bleeder valve on slave cylinder (clutch still pressed in), close bleeder valve, depress clutch. Rinse and repeat, and keep adding fluid to the reservoir to make sure it is never empty. When opening the bleeder, you'll soon hear air gurgle out, then once the pedal pressure is firm and all you get from the bleeder is fluid squirting out and not air, you're set. You can always do it by yourself by using a breaker bar or something long enough to wedge it between the seat and the clutch to keep it pressed when bleeding, but I find it easier with another set of hands.
As an aside, I replaced my old master cylinder with a Nissin one from Advanced, but after a week, the gasket around the triangular-shaped bypass had been pushed out between the plate and the body of the master (also swapped in a Nissin slave cylinder, but have had no issues at all to date). I put in the old OEM master cylinder and have had no leaks. Hope this helps.
1 - 6 of 6 Posts
