i think your wrong, it's the wheel furthest from the master cylinder is done first.its in the instructiosn i linked in my previous post.
drivers front
pass front
pass rear
drivers rear
i think your wrong. i took it directly from the manuali think your wrong, it's the wheel furthest from the master cylinder is done first.
pass rear
driver rear
pass front
driver front
no fluid on the floorSo after you get done bleeding the brakes and you try them out what happens? does the pedal hit the floor? Or does it slowly loose pressure? Is there any puddles of fluid under the car?
+1 FL,FR,RR,RL Is correct as he stated, its not furthest away as it is on older cars. I believe when yuo're bleeding you're not supposed to touch the brake pedal to the floor. Right after doing it did you pump the brakes until yuo felt a little tension. Was you brake fluid ever low? Did yuo by any chance mess w/ the piston on the caliper? you can take it off the car and test if its compressing and decompressing. There was/is no reason for you bleeding the brakes if you didnt disconnect them. good luck, when you think you got it figured out, drive safely and slowly.i think your wrong. i took it directly from the manual![]()
