1 - 13 of 13 Posts
very neat....but also very inacurate. There's more to calculating 1/4 than just horsepower/weight/and drivetrain
There's:
-Horsepower
-Torque
-Weight
-Gear Ratios
-Traction
-Tempurature
-Humidity
-Driver skill
to take into consideration. But it's still a nice lil' tool to get an idea of what you could run
That is a little mixed up. What I have been told over the years is to MAKE more HP , you can take the total weight of the car and divide it by the HP (rough to figure unless you dyno) and that will give you the weight needed to reduce to gain 1 HP. Basic weight reductions.
EX. civic si wieghs 3000 lbs and it makes 198 HP. (rough example, don't forget to include driver's wieght.)
divide the 3000 by 198 and you get 15.1516
So it takes roughly 15 lbs to make 1 HP by using wieght reductions.
Usually the spare, jack, back seats are gone. Easy to replace after the track.
You could also get serious reductions, A/C system, panels,carpet,on and on.
Hope that helps.
Taking a dump before the race is a definate stage 2 reduction! lol!!!!!!
So in order to make 1 HP by dropping wieght
ID10T
Pretty close.
Car weight: 3300 lbs.
Horsepower: 350 hp
Configuration: Rear Wheel Drive
Results
Quarter Mile Acceleration: 13.344 seconds.
Terminal speed: 110.7770 mph.
Car weight: 1 lbs.
Horsepower: 9999999999999999 hp
Configuration: Front Wheel Drive
Results
Quarter Mile Acceleration: 0.0006 seconds.
Terminal speed: 2340000000000000.0000 mph.
Sounds about right.... my Daewoo owns
Kabs said:
Car weight: 9999999999999999 lbs.
Horsepower: 1 hp
Results
Quarter Mile Acceleration: 638151 seconds.
Terminal speed: 0.0234 mph.
SWEEEEEET!
oh wow, according to this i run:
Results
Quarter Mile Acceleration: 17.941 seconds.
Terminal speed: 83.2443 mph
:party:
:thumb:
:driving:
:eek:wneddanc
:eek:wned:
:gaygiggle
There's:
-Horsepower
-Torque
-Weight
-Gear Ratios
-Traction
-Tempurature
-Humidity
-Driver skill
And a little thing called Drag coefficient. For example if it takes a '91 Crx 600hp to get down the track in 10 seconds, it would only take an Insight 400hp to achive the same feat. :thumb:
1 - 13 of 13 Posts
