1 - 10 of 10 Posts
so these will work just liek the spc rears camber kit right?
It will adjust camber yes. The SPC does -3 to +3 degrees. The Ingalls does -1.75 to +5 degrees which is much better considering most ppl are trying to negate negative camber so this can negate up to 5 degrees of negative camber.
What benefit would these provide if i wanted to run -2 degress in the rear, and on stock settings droped on tein springs im already at -1.6 degrees? Would it only allow me to negate the camber to -1.75 total?
Discussion Starter · #9 ·
This will allow you up to -1.75 degrees of camber.
OP ^^^ or do they mount to the stock rear arms?
They replace the factory mounting plate.
1 - 10 of 10 Posts
