1 - 20 of 24 Posts
Hey guys. I wanted to replace the plugs on my SI this weekend. I got some used DENSO iridium plugs with my GReddy kit. (1 step colder,they looked pretty black) My local performance shop only carries NGK. Would anyone recomend NGK's or should I just order the same ones I have now?
Thanks, Evan
Thanks, Evan
I dont know about used DENSO Iridiums but new ones would be great for your kit, if you are planning on running the reccomended amount of boost. Iridium spark plugs have a smaller center electrode, which ultimately means less firing voltage is require, which means you are less likely to misfire.
if I'm not mistaken, Honda usually uses NGK's in their older cars (they came stock in my prelude)
You should be fine with them. I ordered 2 steps colder for my kit from
Spark plug, Spark plug wire, spark plug gap, spark plug cross reference and ignition wires at Sparkplugs.com
How much power are planning on attaining, how many lbs of boost are you running?
You can gap iridiums, just have to be real careful with electrode. Don't use the POS gap ring thing, use feeler gauges. Stock gap is .041 but a smaller gap is better for a turbo application. start around .035 and go smaller. I'm still trying to find some copper cores that fit our cars, if anybody has a pn for one I would be much appreciative.
Why do you want coppers?
1 - 20 of 24 Posts
