1 - 3 of 3 Posts
Dakidizback8 said:
I just got a avic-D3 and I got sound without using the amp by pass. do anyone know how would wire in my sub?
So you integrated your radio into the factory amp using the method by whiterice which includes soldering RCA's to the radio harness? If you did this then the factory sub is working, however you have no seperate control over it. This is the method I used when installing my Z2.
If you used the giant 10 foot long radio harness then you did bypass the amp and the sub will not work. not sure how to actually get it working using this method.
i believe the headunit should push the speakers and you need to connect the amp to the "subwoofer" cables then it should work. thats all i can think of :p
1 - 3 of 3 Posts
