my FA5 going under the knife...(06 up TSX cams)
43568 Views 308 Replies 86 Participants Last post by  vic22vtk
7
FA5 with 06 TSX cams, dyno sheets.
i decided to clean up this original post, alot of dyno sheets now with diferent combinations...
reason for all my dynoing, well my AFR's were a little lean, so im just tryin to get it all straighten out now.
here is a direct comparsion of my car and a Stock Si. stock Si's put down low 170's on this dyno, this SI put down 174WHP with 131 lbs ft, i put down 199WHP with 139 lbs ft of tq
my mods are
fujita short ram
P2R spacer
ported DC race header
NST pulleys
hondata IMG
hondata reflash
06 TSX cams
dyno jet figures with all my mods that are listed 211WHP
the scary AFR on my car with all the mods listed above
AFR on a stock Si
the AFR leans out just right with the CAMs... so what was the problem? FUJITA SRI was letting in to much un metered air and causeing it to lean out over 1 FULL point vs the stock airbox... my findings are the diameter or the fujita is bigger than the stock airbox... and the dividers that the factory airbox have are there for a reason... i got nothing but consistant AFR through the whole power band with the stock box..
here is the fujita SRI AFR vs my Stock airbox AFR
next graph here is all mods listed above with the exception of the P2R spacer vs NO spacer and NO fujita short ram...(stock box) look closely, i picked up 2 lbs ft of tq but i did lose about 8 WHP with the stock airbox but its only over 7500...
dynojet figures fujita VS airbox.... 208.9 WHP with SRI and 201.3 with the stock airbox.
ALL THESE FIGURES ARE SAE CORRECTED!!!!
here is all the cam info again
******** cam part and price info from acuracarland.com*********
14110-RBB-A00 CAMSHAFT, IN. 1 2006 TSX list 420.48 there price 336.38
14120-RBB-000 CAMSHAFT, EX. 1 2006 TSX list 439.13 there price 351.30
DO NOT BUY 04-05 TSX intake CAMSHAFT they are not the same... they have less lift and duration on the highcam lobe.... "14110-RBB-000 CAMSHAFT, IN. 1 2005 TSX list 439.13 there price 351.30" its more expensive too...
  • Like
Reactions: 5
1 - 20 of 309 Posts
Looking forward to this.
word you can use those cams with no tuning huh something for me to think about !
Awesome! Cant wait for this. Plz post dyno sheet.
  • Like
Reactions: 1
i will definately dyno the car after the cams... just tryin to find a dyojet in tha area
Would be nice if you could dyno before the cams as well. Every dyno is different, so having a baseline would be useful. Also interested to see the change in the A/F ratio.
-Freq
Holy crap subscribed. :popcorn:
Dynojet = garbage. Get a real dyno, like a mustang. Haha. Dynojet projects about 10-15% more horsepower than you actually have.
That's the only dyno i have every used is a mustang.
i know what you mean but i wanna have it dyoned on a dyno everyone is familar with... im a dyno dynamics fan...
Of course, you used to own an Evo. :thumb:
A dyno is a dyno. Everyone knows what they are. You can calibrate any dyno to project more horsepower. Im just saying dynojet sux.
what ever you do, use the same dyno before and after. Who cares what kind it is, we just need consistancy. This sounds like a kick ass idea. Get those numbers up soon. Before and After.
1 - 20 of 309 Posts
