I'm going to be running nitrous, most likely a 75 shot. My car's current build (230whp) is:
Engine
Injen CAI (insulated)
Blox 6" filter w/ velocity stack
P2R TBS w/ gaskets
TSX TB
P2R IMG
Go Power drop-in cams
skunk2 header
Go Power 3" exhaust
DIY injected motor mounts
NST pullies
Hondata FP
RDX injectors
Denso iridium spark plugs
Suspension/wheels
Tokico D-spec adjustable gas shocks
HFP springs
2x camber bolts in the front (aggressive autox setup)
Progress RSB
5zigen FN01RC
Dunlop Starspecs
So far I have the ZEX WET nitrous kit with a bottle warmer, safety blow down tube, solenoid/TPS.
I also plan on getting/doing:
RPM window switch ($165) http://www.shop.speedunlimited.com/p-3314-zex-82085-nitrous-traction-control-rpm-window-switch.aspx
Lean shut-down switch ($99) http://www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=67
Wideband/AF gauge ($222) http://www.aemelectronics.com/wideb...og-face-770?osCsid=ir5qcqnnu9rmdqendnanvfcol6
fuel pressure safety switch (suggestions?)
ZEX rapid-fire purge with red LED ($170 for 2 on ebay) http://www.shop.speedunlimited.com/p-3238-zex-82370-r-red-rapid-fire-purge-light-kit.aspx
Direct port kit (I need help finding one that isn't a V8 kit) (suggestions?)
Fuel pressure regulator (needed?) (suggestions?)
Fuel pump (I was looking at the ZEX inline fuel booster, what do you guys think? Will this do the job?) ($190 on ebay) http://www.shop.speedunlimited.com/p-3358-zex-82020-booster-inline-fuel-pump-kit.aspx
Gauges Which are the best/look cool/needed
PSI gauge
Fuel pressure gauge (recommended?)
I'm looking to add essentials and/or eliminate things I may not need on this list
I'm taking any suggestions/comments/advice. Any help is appreciated
Engine
P2R TBS w/ gaskets
TSX TB
P2R IMG
skunk2 header
Go Power 3" exhaust
NST pullies
Hondata FP
RDX injectors
Suspension/wheels
HFP springs
Progress RSB
5zigen FN01RC
Dunlop Starspecs
PSI gauge
