1 - 20 of 1184 Posts
Note: I have updated this original post to include pictures and details from different time periods throughout the build. Please browse through the build thread for more details and pictures =) <3
CURRENT STATUS
THE BEGINNING - Bone stock 2007 Civic Si Sedan
Changes - Chapter 1 - Getting feet wet
Mods: Skunk Pro S II Coilovers, Skunk2 Header, Go Power Exhaust, P2R TBS, JDM Emblems, EBC Rotors & Pads, Painted Grill, HID's & Yellow Fog Lights.
Tune: E-Tunez (Rulo) --- Dynojet 217HP
Changes - Chapter 2 - Getting Purdy
Mods: Megans Racing CF Rear Window Spoiler
Ride Height: Going Lower =)
Changes - Chapter 3 - Bling
Mods: Skunk2 Fuel Rail, PasswordJDM Carbon/Kevlar Spark Plug Cover & Radiator Cooling Plate
Changes - Chapter 4 - More Powa
Mods: Hytech Stage 1 Cams, Go Power Motorsports Valvetrain, Hybrid Racing Tensioner, Skunk2 76mm Exhaust, Skunk2 Intake Manifold, Skunk2 Throttle Body, Go Power Motors Custom Intake, FD2 Final Drive, RDX Injectors, ACT Streetlite Flywheel, Clutch Masters FX200 Clutch, RSX Oil Pump, JDM Valve Cover, JDM Shift Boot, JDM Shift Knob, JDM Dip Stick, JDM Steering Emblem, Hybrid Racing Shifter Bushings (both sets)
Tune: CMB-Tuning (Colombia) --- Dynojet 250HP
Changes - Chapter 5 - Red
Wheels: 18x7 +45 OZ Allegeritta HLT (Red)
Changes - Chapter 6 - Hellaflush
Mods: FD2 Front End Conversion, Mugen Type R Lip, Skunk2 Pro-C Coilovers, Skunk2 Rear Camber Arms, Beaks Bar
Wheels: 17x9 949Racing 6ULR's
Changes - Chapter 7 - ALL MOTOR MADNESS!!!!!!!
Updated MOD LIST
Engine/Performance
ERL Sleeved K24 Block
Wiseco 89mm 12.5:1 Pistons (WPC Treatment on rings & pins)
Go Power Motorsports I-Beam Rods
4Piston K20Z3 Head
Ferrea Valves (+1mm intake)
Skunk2 Stage 3 Cams
Skunk2 Valvetrain
Skunk2 Intake Manifold (Extrude Honed)
Skunk2 76mm Exhaust (Ceramic Coated)
Skunk2 Oil Cap
Skunk2 Radiator Cap
Skunk2 Valve Cover Washers
Toda Timing Chain
Toda Balancer Chain
Toda Tensioner
Hytech Cam Tower Mod
Hytech Type S Oil Pump
Hytech Oil Pan Baffle
ASP Header
Go Power Motorsports Custom CAI
ATI Harmonic Balancer
Driveshaft Shop 2.9 Axles
Injector Dynamics 1000cc Injectors
Walbro 255 Fuel Pump
K-Tuned Fuel Rail w/ Center Mount Gauge
K-Tuned Fuel Pressure Regulator
K-Tuned Fuel Lines & Fittings
K-Tuned Upper Coolant Housing
K-Tuned Idle Air Assist Delete
Hybrid Racing Shifter Cables
Hybrid Racing Radiator Hoses
Hybrid Racing EM1 CMC
Mishimito Radiator
Mishimito Aluminum Fan Shroud
Wireworx Custom Harness
Wireworx ABS Delete
Password JDM Carbon/Kevlar Cooling Plate
JDM Dipstick
Black Washer Fluid Cap
Black Powdercoated Valve Cover/Intake Manifold/Intake Tube/Catch Can
Jotech Performance Custom Breather/Catch Can
MFactory Race Transmission
Clutch Masters FX400
Hasport Motor Mounts
Hondata FlashPRO (Tuned By: Colombia, CMB-Tuning)
Exterior
OEM FD2 Hood
OEM FD2 Front Fenders
OEM FD2 Front Bumper
OEM FD2 Front Grill
OEM FD2 Headlights
OEM FD2 Sidemarkers
Megans Racing Carbon Fiber Roof Spoiler
Mugen Type R Front Lip (authentic)
Password JDM Rear Tow Hook
5% Window Tint (55% windshield)
JDM Emblems (front & rear)
4300k Philips HID
PIAA 5k Side Marker Bulbs
PIAA 5k Turn Signal Bulbs
PIAA Xtreme White High Beam Bulbs
Black Painted Front Grill
Black Painted Roof
Debadged Trunk Emblems
Interior
JDM Steering Emblem
JDM Shift Knob
JDM Shift Boot
Hyper White LED Interior Lights
Innovate Air/Fuel Ratio Gauge
AEM Oil Pressure Gauge
Suspension/Wheels/Brakes
Work Meister M1R 18X9 +25
Work Black Lugs & Valve Stems
Racing Brake 2 Piece Open Slot Rotors (front)
TPM Slotted Rotors (rear)
Racing Brake ET500 Pads (front/rear)
Brembo Calipers (front)
Full-Race Traction Balls
Beaks Lower Arm Bar
ARP Extended Wheel Studs
ICE
OEM Nav
JL Audio 250/1v2
JL Audio 300/4v2
JL Audio 8W3v3
Polk Audio MM6501
Polk Audio MM521
Passport 8500 Radar Detector
Changes - Chapter 8 - Race Gas & More Compression!
Wiseco 14.2:1 Pistons
VP Racing Fuels C85
318WHP (CMB-Tuning & Jotech Performance)
Beast mode!!! =)
Please check the thread for details, plus way more pictures inside.
<3
Discussion Starter · #5 · (Edited)
**UPDATE**
Installed:
JDM Emblems
JDM Shift Knob & Boot
Ordered:
Flashpro
GoPower 3" Exhaust (w/ black muffler)
Skunk2 Megapower Header
Innovative Motor Mounts (Track)
Camber Bolts
Rear Camber Kit
P2R Throttle Body Spacer (red, w/ the gaskets)
HPS Silicone Hose (on back order, grrr...)
Skunk2 Pro-S Coilovers
Hondata IMG
Skunk2 Radiator Cap
Skunk2 Reservoir Cover
Everything will be here next week. Just need to order my HID kits, and purchase my etunez. Other than that I will be buying these rims after everything is installed on the car =]
O.Z. Alleggerita HLT (red)
O.Z. Alleggerita HLT Red Painted
Oh and also ordering some blue LED bulbs for my high beams/DRL
Discussion Starter · #6 ·
**UPDATE**
Installed:
JDM Emblems
JDM Shift Boot & Know
Flash Pro (e-tunez rev 1)
Go Power 3" Exhaust
P2R TBS
CT-E SRI
Hondata IMG
HFP Front Lip
Waiting to be installed:
Skunk2 Radiator Cap
Skunk2 Oil Cap
Password JDM Carbon/Kevlar Radiator Cooling Plate/Intake Manifold Cover/Spark Plug Cover
EBS Rotors
EBS Brake Pads
Buddy Club Coilovers
Ingalls Front Camber Bolts
Ingalls Rear Camber Kit
HID Kit
Megan Racing Carbon Fiber Wing
NRG Carbon Fiber Grill
Red H Steering Wheel Emblem
Misc:
When coilovers and rest of stuff is installed will have my HFP rims powder coated black, and having calipers painted.
Ill have to hit you up next time im in ChuckTown, I would love to check out this build and how your getting it done.
Nate
Nice..wanna know what would make me happy?
I've been looking ALLLLL over youtube for vids of people daily driving...or normal driving their SI's to work or the store or something.
I've seen like 3 vids but that's not good enough. Can you take some vids of your drive to work...or the store and back or w.e? I like to see vids other than SI's in VTEC 24/7
Discussion Starter · #15 ·
Will take one for you today
Discussion Starter · #17 ·
The remaining parts pile =O
There should be an NRG carbon grill in the picture, but they sent me the wrong 1 =[
