1 - 20 of 285 Posts
There are so many threads being created about defoulers, it would be nice to compile everything into a single thread with the hopes that it could become a sticky. I will attempt to do so, addressing issues relevant to those using a race header.
Rationale for defoulers, this from Pro Street:
On ODB-II vehicles (96+), the ECU has two O2 sensors for diagnostic purposes. The first O2 sensor is located before the Catalytic Converter. This O2 sensor is responsible for all the Air/Fuel tuning and is imperative to the operation of the vehicle.
The second O2 sensor is located after the Catalytic Converter. The whole purpose of this O2 sensor is to ensure that there is a functioning catalytic converter in the system. The way it can detect this is to make sure that there is a difference in exhaust gasses between the first O2 sensor and the second. If the same exhaust reading is detected, then the ECU knows that there is either a damaged Catalytic Converter or no Catalytic Converter at all.
The ECU will then trigger a Check-Engine Light. On some instances, the vehicle will be thrown into a "Null" mode where the vehicle will not go over a certain speed and will be basically rendered useless.
This mechanical O2 fix is basically a way to space out the O2 sensor so that it still reads SOME exhaust gasses but it removes the O2 sensor from the direct flow of the gasses as to make the ECU believe there is a restriction in the exhaust gasses such as by a Catalyst.
From E46fanatics:
WHO: People who upgraded to aftermarket headers without installing any catalytic converter will get a catalytic inefficiency error code. Likewise, people who install high-flow catalytic converter will get the same "inefficiency" error codes.
WHAT: Catalytic Inefficiency codes on the post cat 0xygen sensor: P0420 (cylinder 1-3) P0422 (cylinder 4-6).
Ref: http://www.obd-codes.com/trouble_cod...old-bank-1.php
WHY: The reason why your OBD-II diagnostic systems report this error code is because the 02 sensors detect an above normal exhaust reading when compare to OEM catalytic converter. The OEM catalytic converter does an excellent job at filtering/cleaning/converting exhaust fumes into cleaner air. The DME/ECU calibrates its post-cat sensors to the OEM catalytic converter performance and specs. Therefore, aftermarket cats do not clean well enough to satisfy the catalytic efficiency monitoring of the DME. This is a very common problem with aftermarket cats especially the high-flow ones.
An "inefficiency" reading does not mean that your catalytic converter is broken especially if it is brand new. Again, the error codes just means that they are not performing as efficient enough to meet OEM standards.
SOLUTION: There are three feasible options to solve this inefficiency problem
Ignore.
Spark Plug non-fouler (aka Spark Plug defouler)
Software upgrade
-Ignore-Since the post catalytic converter oxygen sensors is purely for emission monitoring it does not in ANY way affect your fuel trim and car performance. Therefore, it is perfectly fine to ignore the check engine light.
-PRO: No time and resources wasted on fixing problem
-CON: Annoying check engine light
-Software Upgrade-Software upgrade from major tuning companies will flash your DME to remove the "catalytic efficiency" monitoring feature.
-PRO: Fast and requires no hardware/equipment modification to exhaust systems
-CON: Expensive
-Spark Plug non-fouler (aka Spark Plug defouler)-By installing the spark plug non-fouler, you are in essence moving the rear 02 sensor out of the direct flow of the exhaust stream/flow. By doing so, you are tricking the 02 sensor will an inaccurate reading. Since the 02 sensors is not directly in the path of the exhaust fumes, it can not accurate measure the exhaust fumes.
-PRO- Inexpensive
-CON- None
Types of defoulers:
1. Angled. As the name suggests, the defouler is angled at 90 degrees, which allows for greater clearance. This is especially important on Vibrant and BuddyClub headers.
2. Straight. These are straight, which seems fine with DCSports race headers, but not the Vibrant and Buddy Club.
DIY defoulers: There have been a number of threads about making your own defouler.
http://www.8thcivic.com/forums/bolt-ons-all-motor/78145-diy-defouler.html
solution: Check engine light w/ aftermarket Headers - E46Fanatics
Installation:
All defouler threads on 8th Gen:
http://www.8thcivic.com/forums/search.php?searchid=2352001
Where to buy:
eBay Motors: O2 sensor angle header WRX STI EVO 350z Civic SI tC RSX (item 250268957202 end time Jul-19-08 21:27:57 PDT)
This guy does stuff for VW's: [email protected] e-mail him with your request.
[email protected]
Mechanical 02 Simulators
A&J Racing :: Intake & Exhaust :: T1R O2 Fix
BLOX Racing Check Engine Light Eliminator - BLOX Exhaust Parts
Universal - Cel Eliminator 963-111-101 >> Weapon R Cel Eliminator
King Motorsports Unlimited, Inc.
Defcon Products : Oxygen Sensor Simulators
Hope this helps everyone out. We want this info to be disseminated to as many people as possible who either have race headers or are considering them.
Please post any extra info you have that would benefit fellow members here on the forum.
Thanks for doing this. I hope it will help out. It will give people something to say "read the damn sticky" to all the people that come in and ask again.
Really Jeremy. I have approached the mods about making this a sticky. How many times everyday do threads and posts come up about defoulers? You and I and a few others have answered these questions a thousand times. People just need to be able to referred to something that can answer all their questions.
You must have a thing for mothers b/c all your threads start with "mother". lol
Were not going to be offering our defoulers. I decided that since people state they need tracking #'s we will dedicate our time to that then doing dynos, installations, r&d etc to help out.
Im sorry guys.
Discussion Starter #9
Im sorry guys.
Original post edited. :thumb:
Im sorry guys.
That sux. That would have been alot of extra money for you guys.
Discussion Starter #13 (Edited)
nice, sticky this, NAOW!
I tried to get Webby to make it a sticky. He included it in Bolt On and All-Motor Stickies. Unfortunately, he made a defouler question a sticky even though it doesn't address anything specifically. I had approached Webby about creating separate stickies for questions asked over and over.
The only thing that could be done would be for someone like yourself to PM and request that it be made a separate sticky or replace the defouler question. I tried but didn't succeed.
Nice post - Should be up top! :bump:
I am glad I found that angled one! hopefully the guy won't stop making them.
Good post, accurrate info.
Back in the day... we used to leave our secondary O2 sensors outside of the exhaust flow, with a cap over the end. As in, sitting in the engine bay with easy access.
NO CEL, seemed to work fine.
Another option was to make a secondary O2 sensor simulator, we had to make our own but now you can buy them. A quick google search pulled up the below:
-Steve
Discussion Starter #17
-Steve
Let's just hope the EPA does not get wind of this. Casper's Electronics was beach slapped big time for selling a similar device. Casper's Electronics, Inc. | Civil Enforcement | Compliance and Enforcement | US EPA
Discussion Starter #19
Let's hope the epa does more important matters than a lousy defouler.
The device mentioned is more than just a defouler. It is an electronic device that can trick the ECU. I think the EPA is not going to mess with a little metal piece of pipe that has a 90 degree bend in it. However, an electronic device that can override the ECU is another thing to them.
ErichPryde said:
Dear ryker,
You have received an infraction at 8th Generation Honda Civic Forum.
Reason: thread rules violation
ryker, I don't have an option for "suggests breaking the law," so I'm marking this as a thread rules violation. Please keep further posts free of anything that seems wrong or illegal.
1 - 20 of 285 Posts
