1 - 20 of 20 Posts
· Registered
Moddiction Blue tinted convex side mirrors for the 8th gen civic SI.
Should fit non SI model as well.
For Sedan click HERE
For Coupe click HERE
Product Description
-Honda Civic 2006-2010.
-Available for Sedan or Coupe.
Price is for a set of both Left and Right side replacement mirror glass.
-Eliminate the blind spot.
-Reduce Glare.
-Beads water better.
-Blue tinted appearance. Not an overlay. Actual tinted glass. No peeling or fading ever.
-Great price.
-Can be stuck on top of oem mirror with double sided tape but we recommend replacing the stock mirrors with these. DO NOT use double sided tape when doing the replacement method.
-If sticking over stock mirrors tape may wear out over time and lose it's hold
-Free shipping within the U.S.
-Black housing is not included. This is only the mirror glass and 3M double sided tape (for overlay if wanted). These replace the oem mirrors inside the black housing.
Mirrors with black housing pop out of the body colored mirror part. A flat head makes it easier to pop them out of the body colored mirror part. Once out the black housing with mirror inside needs to be carefully heated with either a heat gun or in a pot of hot water to soften the black housing and allow the oem mirror glass to be removed. Once removed heat again and CAREFULLY install the new Moddiction convex mirror into the oem black housing.
Please be careful when installing mirrors as they are fragile and can break. DO NOT PRESS ON THE CENTER OF MIRROR WHEN INSTALLING!
· Registered
Discussion Starter · #4 ·
I have a sedan with hybrid mirrors. I think hybrid mirrors are a little bit different would they fit?
I think the Hybrid may be different as well. If they aren't exactly same size as the si and non hybrid models they will not fit. Some cars have the heated option which won't transfer over to these but the mirrors will still fit in the housing.
· Registered
Discussion Starter · #13 ·
I will try to find a local civic to get an install video on but it is actually quite simple once you just give it a try. The mirrors pop out and then all you have to do is heat it up in hot water to make the black housing more pliable and then pop mirror out using a credit card around the edges. Heat again to put new convex mirrors in and pop them back into the car.
1 - 20 of 20 Posts
