441 - 460 of 501 Posts
Yes, here is the engine, in this also the piston does not beat the cylinder .. But too complicated and I still do not like modes. And the lateral force of the plunger and so-called tobaccos somewhere is lost ...
But he will read for it, what it gives ... I do not have to tire about writing the advantages of my crosshead .. :D
Wiseman Technologies, Inc.
And here is how something is not going on when crosshed ..
And now he will not ...
Andrew :wavey:
So I continued to divide the hair into four... :D
Yes, we slowly develop this way of bypassing the lateral force of the piston .. here, that's all you have to do is one lever that has a half-ring at the end, but the other way round. This way one pulls up and the other down during the movement of the lever ... It can be used for a full four-stroke engine .. Well, see how easy we can cool the water piston ..
Regards Andrew :wavey:
Does not this remind you of the mechanics drawn by James Watt ? But it's necessary to back 250 years back ..
Hand-drawn diagram by James Watt explaining his discovery of the "parallel motion" in a letter to his Sohn: "The idea originated in this manner. On finding double chains, or racks and sectors, very inconvenient for communicating the motion of the piston-rod to the angulat motion of the working-beam, I set to work to try if I could not contrieve some means of performing the same form motions turning upon centres, and after some time it occured to me that AB, CD, being two equal radii revolving on the centres B and C, and connected together by a rod AD, in moving through arches of certain length, the variations from straight line would be nearly equal and opposite, and that the point E would describe a line nearly straight, and that if for convenice the radius CD was only half of AB, by moving the point E nearer to D, the same would take place; and from this the construction, afterwards called the parallel motion was derived."
Of course, instead of a rope, you can use any type of parallel movement mechanism.
https://en.wikipedia.org/wiki/Parallel_motion
And of course, it's getting higher and higher speed after that ...
So this Wats is not bad anymore .. but this string can have such a form of springs from the watch's bannister .. and then it is the simplest solution and guaranteeing higher revolutions .. obviously the ideal is Peaucellier-Lipkin, but also is the most complicated .. But after some analysis, to which the arms attach to the connecting rod, i.e. which carries the main forces, the rest may not have to be a monstrous size ..
In any case, the use of a traditional crosshead certainly became archaism ... because with the use of any of these solutions, the side force on the crowd does not occur, and was not moved below, to crosshedas, and was liquidated at all ..
Also from my drawing you can see that a very easy way we can do cooling with the water of the piston ..
This can give us, due to its very low temperature, a change to Teflon efflorescence and one would be tempted to completely give up the oil.
And this is a very important matter, which allows us this construction, so it seems to me that maybe you can do practically this matter and try some teflon bearings and seals
https://en.wikipedia.org/wiki/Peaucellier–Lipkin_linkage
Here is the animation of THE PEAUCELLIER-LIPKIN LINKAGE which is automatically downloaded
http://kmoddl.library.cornell.edu/tutorials/05/
Normal position engine crosshead Peaucellier-Lipkin :rolleyes:
Andrew :wavey:
Historical notes
Sylvester (Collected Works, Vol. 3, Paper 2) writes that when he showed a model to Kelvin, he “nursed it as if it had been his own child, and when a motion was made to relieve him of it, replied ‘No! I have not had nearly enough of it—it is the most beautiful thing I have ever seen in my life.’”
Which of these three mechanisms to use ... and here the magnitude of the lateral force on the piston in the C-spot ... as you can see on 1/3 of the torque it achieves .. THEREFULLY IT WILL NOT BE HERE ... :clap:
Reaction Torque in Crank Slider Mechanism :: Explore :: Mechanical Expressions
Andrew :wavey:
Which to use?
This is a good question ..
With a new construction a lot of unknowns ... here is one but also a new 3 ways to connect the connecting rod ..
And not only the mathematics of movement, but now all force must be determined ...
A lot of work for sure ..
I wonder where this side force acting in the crosshead has died? :wheee:
Andrew :wavey:
Here are a few more alternatives..
Such animation, so that we know what we are talking about ..
Well, here's the crosshead but it's applied to my new 4 stroke ... we gain a lot ... for my experience with this engine, we now get 1 liter capacity of the main piston, about 300 hp at 5000 rpm.
Of course without NOx, because the pistons will be cooled with water ..
Well, that's what to fight for ...
Andrew:wavey:
It's best to see in such a drawing .. so dead force can only give one's place on the casing in one place ... only pivot is in the place, which gives very little resistance to movement on a flat plane .. an element loaded with this force ..
Andrew :wavey:
Always every two connecting rods and two cranks on the crankshaft in a 4 cylinder engine are always less .. :wheee:
Andrew :wavey:
Had the twilight of long crankshafts ready to be ready ... ?
The connector between the arms as they will have the diameter of the main bearings of the main crankshaft, this should be enough....
Andrew:wavey:
Principle of operation of a 6 cylinder engine with a crosshead, Watt type, Peaucelier or Feliks line crosshead .. So what gives us ... no friction piston by cylinder, so we can give up the oil for lubrication (oil pumps too), and gives 15% torque increase. Possibility of excellent cooling of the pistons with water, which will increase the compression ratio by 2 units. this is the next 10% .. Well, ecology, no oil burning, and less NOx, because in the chamber lower temperature ..
And the lack of crankshaft, because one crank with the connecting rod is hardly called a shaft ... if the engine has 16 cylinders .. :rolleyes:
http://www.railroadhandcar.com/projects/video-files/keystone-family.mp4
Andrew:wavey:
In other forum :
Posted Today, 10:46
Greg Lo****, on 06 May 2018 - 06:13, said:
"You think that 15% of the IMEP is absorbed in sidethrust on the pistons? Don't think so, most of the FMEP is piston rings."
Well, unfortunately this is not true ... But so far people have thought so ... If you liked playing with a calculator, which I published a few posts above, then you probably already knew how much the reaction of the piston to the cylinder ... Publishes again with my setting value, and clearly see that this force reaches even 30% of the value of the force giving the torque .. derived from the combustion of fuel .. Contrary to appearances, the force of pressure on the piston ring piston is small compared to this force, because it is in the pressure of relatively the small force coming from the bending of the piston ring, which, as you probably know, we can easily squeeze with fingers ... ..... So that the force in comparison to the force of lateral force is many times smaller, if the engine performs heavy work .. And is independent of the load of the engine, it has practically constant value ... independent of the engine load.
Here you have a screen shot in the picture, because as you can see, you do not like to play with calculators. :wave:
Andrew :wavey:
Greg Lo****, on 09 May 2018 - 05:34, said:
"I'll take real data even though it is hard to understand, compared with cartoons, thanks."
because if they learned from such scientists, which draw their conclusions a bit, it's no wonder .. And then they do not know what to pay attention to, and they deal with matters that are not very important, not important.
Strength tensions piston rings is `5 KG, and the side force of the piston is 150 KG, For them it is" half ".. :laugh:
https://www.sciencedirect.com/science/article/pii/S0301679X17303584
http://www.new4stroke.com/sily w cylindrze.pdf
It's good that you know someone who will lead you out of this error ;)
Andrew :wavey:
Eat here and imagine that this side force is one-tenth of this force which has been hit by a connecting rod ..
And in the era of steam engines, they did not know what the water cooling of the piston might be useful ... I know ...:D
But I like my cartoons ... here is what the prototype apparently traveled over a million kilometers .. Well, but I would certainly do without 2/3 crankshaft and 4 connecting rods less ...
https://en.wikipedia.org/wiki/Commer_TS3
and here, in this photograph, it is perfectly visible that if you replace these connecting rods and the crankshaft for these 3 additional cylinders 9 Next 6 pistons), for which you can clearly see that the place is, and outside put one crank with two connecting rods, then the strong , pratically with the same dimensional parameters and the same could be more likely to have TWO TIMES more power ... If like comon rail to use, then surely and the plane would be suitable with such parameters ..
One idea was enough.
https://www.flickr.com/photos/[email protected]/galleries/72157628859068527/?rb=1
History - www.commer.co.nz
Well, if we were to convert the Rootes T4 version, then it would be 400 Hp with a good speed for the propeller.
Here in the movie you can hear that when they "defraud" it's almost like Formula 1 rolleyes
And it would be twice as good ...
A small crankshaft at the front and an additional lever ... I would have put in a good turbocharger yet, but I would leave mechanical roots, too... :love:
Commer Feliks
Andrew:wavey:
Yes and in this even 8 cylinder engine (8 x 2 piston), only one crank and one "real" connecting rod .. ..
Do you know how many reciprocating masses less?
Andrew:wavey:
