I would think it would be really heavy... probably great for tractor type applications, where durability over weight would be key; looks very sturdy, but as I said, heavy, and quite tall.
Weight piston and valve same diameter - 62 mm
Right now without springs. Only retainers.
So that you get rid of the doubt next photographs with accurate data :
Diameter popped 75 mm , diameter piston 76.5 mm
Right now are you shure ?? Any washes.
Weight popped 75 mm 1000 G
weight piston & rod 76.5 mm 850 G
weight popped 62 mm 400 G
weight piston & rod 62 mm 370 G
But the window of the flight of the valve of 75 mm is only 64 mm, what is very similar to the window of the flight piston 62 mm .
That is it results from it that the valve of 75 mm is giving the same flight as the piston 62 mm that is 1000 G to 370 G !!!!!
==~~ 2.5 more weight popped to piston& rod !!
It only looks impossibly. but this way is.
In principle ,for them greater popped/piston diameter, it is this difference in weight will be to the benefit of pistons.
Since when the keg came into existence, for it is her shipping by ships constituted a spot of bother. That is how, they forgot to attach, while swinging the ship rolled from one side to other side, hitting in not around with great energy. There was this great danger for the crew. That is how, they forgot to attach, while swinging the ship rolled from one side to other side, hitting in not around with great energy. I decided to use this energy for the production of the electric current with the help of the oscillatory dynamo. It is a pendulum driving the oscillatory dynamo around so with keg. It will be sufficient to install shipboard or for other swimming raft, and during waving we have the electricity, rather than danger
block of osillating dynamo:
Regards Andrew
