1 - 4 of 4 Posts
i want an easy wax to use, basically spray on wipe off. i dont want to wait for a haze then have to wipe. anyone have any experience with this wax?
I use it as an in between wax, works great. No waiting, just spray on and wipe around the section you're working on. Then flip towel and dry.
One of the better spray waxes/ sealants is: Duragloss Aquawax, Optimum Car Wax, and Optimum Opti Seal. Personally I would for with Opti Seal as I heard it lasts a fair bit on its own, and is easy to apply and you can get about 25-30 applications before you run out. Use it sparingly with the foam applicator, no need to worry about plastic, glass, and no buffing required, it dries by itself as soon as its on the surface. If you see streaks or haze, you used too much.
Optimum (OPT) Opti-Seal - 8 oz | Detailed Image
If your going to purchase it, use 10offG35 as a discount code for 10% off!
Good Luck
PS: http://www.detailedimage.com/Ask-a-Pro/optimum-opti-seal-spray-sealant-product-review/
Theres a Review :)
1 - 4 of 4 Posts
