I've already searched but cannot seem to find any answers to me question. So here goes.
17x7.5 +30 225/50/17 Front
17x8.0 +33 235/50/17 Rear
This is the setup that I plan on running and was wondering if it will fit.
Thanks for the help on the info in Advance.
Raymond.
I did a write-up awhile back:
http://www.8thcivic.com/forums/showthread.php?t=47788
Your setup there will rub, badly. Not to mention, it's staggered backwards--on FWD the larger offset and wider tires should be on the *front* not rear.
Thanks for the info aki, as i was about to put my old wheels onto my brother's civic and was wondering on the clearing issues.
im still not really used to these super high offsets haha.
FAQ: Going low offset
Your setup there will rub, badly. Not to mention, it's staggered backwards--on FWD the larger offset and wider tires should be on the front not rear.
How about this. I copied it from the website. Theyre xxr 567 18" rims. Theyd look wicked. It says bolt pattern is universal
  • Wheel Style: 567
  • Bolt Circle: 5 x 100
  • 5 x 4.5
  • Wheel Diameter: 18 in.
  • Wheel Width: 10.5 in.
  • Offset+20 mm
  • Backspacing: 6.53740157480315
  • Finish: Candy Red
  • Center Bore: 73.1mm
