1 - 7 of 7 Posts
i noticed that in the cam phasing tables of my cobb map that there are MAP values instead of MAF. I was under the impression that my AP datalogged and tuned exclusively using MAF based tuning since I have not adjusted anything. can someone explain why this is and how i can read/use those MAP values?
do you know where i can learn how to read the MAP values? for example waht map value corresponds to WOT etc.?
MAP can be read in different ways and depending on your altitude it will vary. I believe with the accessport if you see anything close to the 90's or 100's is WOT, I will take a look at some of my datalogs when I get home to confirm this.
Discussion Starter · #6 ·
awesome thanks for the help, is there a reason on the cam angles table that the map values go well above 100 into the 300s?
E-Tunez FTT!!!
It's the how you are displaying the units, your probably have it set not read standard units. Go to Edit --> Configuring Options --> Check "Show Standard Unit" tick box. That should bring you back to normal.
1 - 7 of 7 Posts
