1 - 3 of 3 Posts
So, coming from using an AP, I am used to tuning the MAF first. This always requires several miles to allow fuel trims to settle before making adjustments.
Obviously, with MAP there is no MAF to calibrate, so I assume I can go straight to fuel. How many miles should I give each change to settle, if any, before data logging fuel & making adjustments?
there is no spoon
No miles. Just make sure the car is fully heated up before you start touching anything.
In Hondata's MAP tuning, there is no LTFT. Fuel is what it is, immediately.
Oh, and don't touch the WOT Lambda tables. Those are of no use to you. All of your fuel tuning happens in the Fuel Low and Fuel High tables, per cam angle indice.
You should watch Vit's WOT fuel tuning video on flashprotuning.com
1 - 3 of 3 Posts
