:yeahthat: If you have to hold it in order for the light to stay on, something is wrong, take it back to the stealership asap.:sadwavy:DNieves said:You have to tap each map light to turn on then tap them again to turn them off -they stay on without having to holding onto them the whole time. You're either not pushing in all the way or the switch(es) are bad or maybe the bulbs are improperly seated.
Wow after reading some of your great posts like this one, I have one question to ask are you retarded?I haven't brought it to the dealer, Im just reading the manual. Im really gettin pissed.
The light switch has two positions, the door and the off. when I push the switch towards me, it lights up but as I remove my hand, it turns off. aargghh
I can't believe how retarded you're being. Not saying you're retarded but you must really not be thinking this through.my map lights are still not working. A question. on what switch do you put the map lights for it to light up? I put it on the door it doesnt light up, I put it in the other switch but still it doesnt light up. I press both spot lights but still doesn't work. I think Im going crazy
I've done that already. Alot of times. Those f#%ckin lights work when the door is open but when I close the door, I tried pushing those lights but doesn't workI can't believe how retarded you're being. Not saying you're retarded but you must really not be thinking this through.
1. Put the switch to door.
2. Unlock your car, open door [lights should be on].
3. Close door [all lights should turn off]
4. Look up and you'll see two map lights. Push them in, and they should turn on.
You're 32, why can't you just kindly explain if he's doing it wrong?Wow after reading some of your great posts like this one, I have one question to ask are you retarded?
Try replacing the fuse and/or light bulbs?my map lights are still not working. A question. on what switch do you put the map lights for it to light up? I put it on the door it doesnt light up, I put it in the other switch but still it doesnt light up. I press both spot lights but still doesn't work. I think Im going crazy
