1 - 6 of 6 Posts
Note: I have no financial interests in this project, but I have been both an alpha and now beta tester of it.
It's for the first gen Civic hybrid only (2003-2005)
retepsnikrep over at insightcentral has designed a device to intercept the signals the ECM sends the MCM and alter them giving whatever assist or regen you command (or disable assist/regen if you care to).
Imac&c hch1 civic - Insight Central: Honda Insight Forum
I've been using it for the past few months and it works great. Obviously a human with knowledge of the route can do a lot better at using the IMA system than a dumb algorithm guessing what is needed from pedal input and speed... for instance, I use the the longer stretches of my commute to charge the battery the most I can while staying in lean burn so I have plenty of SOC to add when it turns start/stop.
So far I've managed to improve my commute average from 49-51mpg to ~ 54.5mpg even while outside temperatures have been dropping.
The install is pretty easy for anyone with a pair of wire strippers/crimpers (though I'd probably solder the connections to make sure no vibration loosens them). The device goes in line with the single wire serial connection (two splices: one to the MCM side, one to the ECM side). Power comes from the +5V and GND connections also from the ECM, so two more splices. I wired mine with CAT5e, you could also use a 6' USB cable.
Here's the whole thing:
The PCB is simple and very tiny, the real magic is in Peter's software (he's been working on decoding the I2C signals from the first gen Insight for years now). It's so tiny that the entire device, buttons and all, mounts right to your e-brake or shifter knob like so:
Here it is installed... I've since moved it to the side so the assist/cancel/regen buttons are under my thumb instead.
I might add that Peter's OBDIIC&C gauge is an absolutely invaluable go-along with the IMAC&C.
https://lh6.googleusercontent.com/-s-e6M-1KKFA/UHNSxfsd_kI/AAAAAAAAE0M/uKOftyo37oU/s144/IMG_20121008_175209.jpg
Sam
That's awesome
Any hybrid I would buy will need to have a mod like this available. Full control of Regen and assist is where it's at.
Still loving this thing too :).
It makes for some fun around town driving... seems to give you the best "kick in the pants" in 2nd gear.
Sam
Awesome! This would definitely help maintain the battery better and give extra oomph when needed! Good job!
1 - 6 of 6 Posts
