1 - 20 of 20 Posts
Anyone know where I can get a good deal for the 3" universal fit? Going to weld it on since my CEL for my BCRH comes up every once in a while.
Procivic had the lowest price but their shipping is too high.
Thanks.
CHOO-CHOO!!!!!!
NA06SI has the Magnaflow HFC welded onto his BCRH. I remember hiim saying the HFC was $100. You might want to check with him, to see where he got his.
Discussion Starter · #7 ·
Good question... Will 3" fit the BCRH? I'm assuming it would since it says that it is a universal fit.
Im going with the 2.5" inlet/outlet. Anyone know where I can get the flanges to weld on to this cat? I know ones a 3 bolt and ones a 2 bolt.
i might get the Strup header and was planning on welding a magnaflow cat. I'll need the flanges too but I dont know which one I'll need...When doing this I guess we have to relocate the hole for the second O2 sensor right?
Supa Ninja, ur setup looks awesome! Good job man. Thanks for the info on excelerate, ill give them a call and grab some flanges, order a bung from summit racing, then get the cat and put it all together.
Ive got a BCRH and need to fab up a cat to bolt in, in place of the test pipe. In no way am I destroying my header!
happy -thanks, its a custom 3" that I had a local hot rod shop fab up.
andrew- I got the bung from excelerate also, should save you some shipping.
Bumping an old thread. :bunny:
Would the 3" converter work well with a Skunk2 Alpha header and Invidia Q300?
I bought the 3" OBDll version thinking I was going to weld it onto the Invidia header and Q300, but ended up with a Skunk2 Alpha instead. Now I'm not sure if I should just go ahead and use the 3" or switch it for the 2.5" OBDll one because of the smaller collector on the Skunk2.
1 - 20 of 20 Posts
