1 - 7 of 7 Posts
When you lower your car do you only need springs or do you need to replace the shocks too. Sorry i am a noob.
Thank you in advance
If you use lowering springs to lower your car you will need aftermarket struts/shocks and camber bolts/arms if you want to do it right.
You don't need them right away but why make yourself do double the work and spend more money. You will have to install the springs + camber bolts/arms and then get a alignment. Then install the struts/shocks later on and get a alignment.
Do it right the first time or get coilovers + camber bolts/arms. :thumb:
Plus search the forum, all your lowering questions can be answered on the Suspension section.
Discussion Starter · #6 ·
K thanks for your info, sry for cluttering the forum i guess. How much would this all cost tho?
Discussion Starter · #7 ·
OOps i should have read the first thread, my bad. Really sorry about cluttering the forum. Ill do better to read the obviouse.
1 - 7 of 7 Posts
