1 - 6 of 6 Posts
I want to stay OEM for now
my first choice are 17" from an 2006 or 2007 (8th gen) Si wheels but i heard that i need a spacer - is this true ?
If so i will look for something that is a direct fit.
Will Acura TSX wheels fit perfectly ?
LX/EX=55mm offsets VS. SI 45mm. You will need at least 3 mm spacers in the front to use the SI wheels or the front calipers will hit the front wheels.
TSX wheels also has 55 offset.
ebay sells cheap spacers for about $20.00 for 4
It works....no problems at all...I had them on my lx without a spacer for a while and had no problems until I heard it was not advised to run the si wheels without spacers, then I got them off ebay for cheap.
I'd like to get new wheels for my 07 LX. I'd like to go with a wider wheel than stock but stay 16" to use up my original tires. I was hoping 225-50/16 would fit but apparently they aren't an option.
1 - 6 of 6 Posts
