1 - 9 of 9 Posts
I DD my si, don't want to go F.I., but what kind of mileage can you get out of upgrading the internals? ie...springs, valves, retainers, port n polish, etc? Thank you for any insight.
Valve springs, retainers, valves PnP, are only necessary if you are getting stage2+ cams.
Stage 2 cams should work fine for ages with a good tune, Stage 3+ cams is where you might run into longterm issues.
:yeahthat: Good info
Discussion Starter · #4 ·
Thank you, what would be considered stage 2? Different companies call their stuff different things...ie...skunk, go-power etc...
I think most companies' stage 2 cams are created with the same general power goals in mind. While "stage 2" itself does not mean anything technically, I've always thought of it like this:
Stage 1: Mild cams. Something of little more value than TSX cams but retain full driveability.
Stage2: Street oriented aggressive cams. More aggressive than some people want in a daily driver, but definitely still usable in daily driving. Should upgrade valvetrain.
Stage 3+: Race cams. Too aggressive to use practically on the street. Should be used with fully built motors.
with the setup i/h/e + stage 2 cams and tsx tb with portmatch you will get max 310mi on 1 tank of gas.
completely stock I got 350...so just expect to lose about 40-50 miles per tank.
Tuning is the key to maximize your MPG, when I had a bad tune I got max 250mi on a tank, it made less power too.
I wouldnt say that.
A lot of stage 2 people will see an increase in MPG if they use low throttle, just do to the increase in power.
MPG is all based in the tune, a well tuned car can easily match the stock MPG figures.
1 - 9 of 9 Posts
