1 - 1 of 1 Posts
I have a leak and can't figure out where it's coming from. I think it's power steering fluid, but I'm not 100% sure. The power steering fluid level in the reservoir is barely dropping, if at all, and I haven't had to add any power steering fluid. I recently replaced the o rings on the high and low pressure lines of the power steering pump. In April 2020, I replaced the valve cover gasket and the cylinder head plug/cap and there is no oil leaking from those. In May 2020, I replaced the variable valve timing solenoid gasket (15826-RNA-A01). There appears to be liquid on the power steering pump, and moisture under the PCV valve.
I have included photos from under the car and from under the hood near the PCV valve. If anyone has any ideas where the leak is coming from, and how to fix it, I'd appreciate it! (I apologize in advance for the photos, I'm having some troubles uploading them to this thread)
Thanks!
Automotive lighting Automotive tire Flash photography Automotive design Gas
Automotive lighting Automotive tire Motor vehicle Bumper Automotive design
Automotive tire Automotive lighting Automotive design Alloy wheel Wheel
Automotive tire Motor vehicle Automotive design Gas Automotive lighting
Gas Auto part Metal Automotive wheel system Automotive tire
Automotive tire Gas Auto part Motor vehicle Machine
Eye Jaw Flash photography Sculpture Art
Automotive tire Motor vehicle Tread Automotive lighting Bumper
Automotive tire Tread Bumper Motor vehicle Automotive design
Automotive tire Alloy wheel Motor vehicle Rim Automotive fuel system
1 - 1 of 1 Posts
