1 - 12 of 12 Posts
It'll cost a bit of dollars to eliminate this hopping so it's best to just use your clutch to keep it to a minimum while racing.
Sometimes your wheels will spin smoothly and sometimes you get the hop.
Laying into the throttle while hopping could snap your drive shaft as the wheel spins for a quick second then grabs and jumps again.
If you feel it starting to jump then lay off or compensate with the clutch.
Mike
i'm not a fan of the above explanations, it can be said with much more clarity...
I am in class right now, but if i remember will post more later... axle hop happens... its bad, but i wouldn't think anything was going to break right away...
1 - 12 of 12 Posts
