1 - 6 of 6 Posts
I've been researching.
i had no luck this far.
Is there a DIY for lamin-X yellow for the Fogs?
i really want to do this...but i dont have a clue.
i really appreciate any info and feedback!
mike
Best think I can tell you about applying them is to clean ur fog really good then, just start on one corner and press down making sure you get all the bubbles out as you work your way across the entire light. Its kind of hard to get it lined up, but if you mess up you can peel it off and try again.
make sure you buy some goo gone for when then burn and you have to replace them.
^^ i think mine burned becuase they bubbled up pretty bad...if you touch them when my HID's are on they are extremely hot! But, even so they look really good at night.
(55 watt 10,000K headlight...30 watt 3,000K fog light)
1 - 6 of 6 Posts
