1 - 1 of 1 Posts
KSPORT's Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
Kontrol Pro
•36 levels of adjustable damping
•Made from high quality 6061 aluminum with T6 for increased hardness
•Compression/Rebound adjustable
•Adjustable spring perch for height adjustment
•Adjustable body allowing maximum suspension travel
•Pillowball top mount with adjustable camber (not available for some models)
•Monotube high pressure design reduces oil leakage
•Electroplated body for protection from corrosion and rust
•One year limited warranty
2006 ~ 2011 - 2Door/4Door including Si - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
GT Pro
•Inverted steel shock absorber for durability
•Lower center of gravity and higher chassis rigidity
•Designed to reduce friction for cooler shock oil temperature
•Inverted design like vehicles in WRC and all JGTC cars
•36-way adjustable damping
•Made from high quality 6061 Aluminum with T6 for increased hardness
•Adjustable spring perch for height adjustment, •Adjustable body allowing maximum suspension travel
•Pillow Ball Top Mount w/ adjustable camber (not available for some models)
•Monotube High Pressure Design reduces oil leakage
•One Year Limited Warranty
Rally Spec GR (Gravel) or Rally Spec AR (Asphalt)
•Special designed springs for rally conditions
•Extended Piston Stroke
•Reinforced internals to withstand extreme track conditions
•Compression/Rebound adjustable, Adjustable spring perch for height adjustment
•Pillowball top mount w/ adjustable camber (not available for some models)
2006 ~ 2011 - 2Door/4Door including Si - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Version RR
•Aggressive valving and spring rates
•Race applications only
•Pillow ball top mount w/ adjustable camber (not available for some models)
2006 ~ 2011 - 2Door/4Door including Si - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Circuit Pro
•Remote reservoirs for independent rebound and compression adjustment
•Includes shock dyno results, and tuned to your needs
•Added oil capacity to dissapate heat and improve performance
•860 possible damping settings
•Adjustable spring perch for height adjustment, Adjustable body allowing maximum suspension travel
2006 ~ 2011 - Sedan FD1 - For all Motorsports - Height/Ride Adj - 860 levels of dampening positions with remote reservoirs - Fr Pillowball Up Mount / Uses Rr OEM Mount
2007 ~ 2011 - Type R Sedan FD2 - For all Motorsports - Height/Ride Adj - 860 levels of dampening positions with remote reservoirs - Fr Pillowball Up Mount / Uses Rr OEM Mount
2007 ~ 2011 - Japan Spec Sedan FD2 - For all Motorsports - Height/Ride Adj - 860 levels of dampening positions with remote reservoirs - Fr Pillowball Up Mount / Uses Rr OEM Mount
GO TO NOPI KSPORT Catalog for model specific images and details
Contact the salesmen below or PM me for our best deal on KSPORT Coilover Systems
1 - 1 of 1 Posts
