1 - 20 of 225 Posts
here's how to disassemble a k20z3 engine.
Why do this ?
valve replacement
cam install
k20a2 oil pump installation
ARP rod bolt installation
bearing inspection
blown head gasket
timing chain replacement
those are just a few
assuming the valve cover is already uninstalled, this is how to do it.
50mm crank pulley removal key is needed, along with 19mm socket. long breaker bars are needed as this thing is torqued down real tight.
14mm socket to remove 4 timing cover mount bolts
10mm socket to remove timing cover bolts, there are 3 that go from the oil pan into the cover and the rest are forward facing
pry cover off
here's what we're looking at now, the timing components
remove cam pulsar plate by hand
pull back on chain tensioner guide(guide on the left) and put pin into timing chain tensioner hole, remove 2 10mm bolts on TCT and remove the TCT. Remove 3 10mm bolt on chain guide and remove chain guide(guide on the right)
loosen 2 cam tower bolts with 12mm socket and remove chain cover
pull of the timing chain
loosen cam cap bolts with 12mm socket
use this sequence for proper loosening sequence
loosen 2 10mm bolts on rocker assembly on cyl # 4 side (flywheel side)
lift off rocker assembly, careful as it will push to separate keep a firm grip until you place it down in a secure area
cylinder head removal
remove lost motion springs and set aside(preferably near rocker assembly)
loosen and remove 10 head bolts, the socket I used was a 9/16th star socket.
use this sequence to avoid warpage
place cylinder head aside in secure area
now we see some pistons, I sprayed mine with wd40 to clean off the carbon buildup hence the weird look.
remove 2 14mm bolts and remove ac compressor bracket from oil pan
spin motor around on engine stand
loosen and remove 10mm bolts holding the oil pan onto the block, off memory there are 22 of them
big flat head screwdriver and pry off the pan, there are 2 wedges to do this 1 on each side. do this carefully to break the seal then lift it off
loosen and remove 3 10mm bolts and remove the oil chain tensioner.
loosen 2 14mm and 2 12mm bolts from the oil pump, lift and move oil pump until you're able to remove the oil pump chain.
remove oil pump
short block after cleaning
and all the parts that we just removed.
non yet :) i wont be doing engine work for a while. but i think there is an online manual for the k20 right with torque specs? you should edit that in you OP.
I can totally see some kick over toquing and braking bolts or stripping out the aluminum haha........ damn
yaaaaa but once they remove the parts, they willll have to put it back together. most of these kids dont even know that they need varying torque for bolts.
but all in all i love this thread, *bookmarked*
and PS why are all the 8thgen Si enthusiasts everywhere BUT nor cal?
i know a couple of cool norcal si owners, they drive all the way down here for some work on their cars.
1 - 20 of 225 Posts
